Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 55
Thread: Race and rally gearboxes 901/52 etc
  1. #21
    Oct 2008
    Burford, ON, Canada
    So for 1967 there appears to be two programs for 901/5x transmissions. The first was just marking the special type on the cases along with a regular serial #.
    901/5x known in 901/02 series 10xxxx
    901/5x known in 902/1 series 13xxxx
    Perhaps this became confusing, and by calendar year 1967 they had set up special serial # series for the various types
    option 9591 type 901/51 10001 highest known 10004 ratios for Hillclimb
    option 9592 type 901/52 20001 highest known 20008 ratios for Airport
    option 9594 type 901/53 30001 -------------------- ratios for Fast Race
    option 9593 type 901/54 40001 highest known 40004 ratios for Nürburgring
    when a ZF limited slip differential was installed during assembly the numeral 9 was stamped between the type and serial #
  2. #22
    Senior Member 2.5MFI's Avatar
    Sep 2006
    Bend, Oregon
    Adding to these special transmission type's, I have a very odd Ring & Pinion set. I have brought this up before ( thanks Jon ) and hoping maybe now there is more information out there. I have a 8:35 R&P set for a 901/911 gearbox. Porsche part number 901.332.252.00. I can't find any information on it at all. It's like it never happened, never produced, doesn't exist. Must be another one out there? Photos below.
    Mark Jung
    MFI Werks
    Early 911S Registry #972
    Carrera T w/LWB, MT, RWS, PCCB
    72 T 66 x 100 MFI Twin Plug Coupe
    R Gruppe #686
  3. #23
    This pinion shaft, with the castle nut, was in a 901/51 “R” trans.
  4. #24
    Oct 2008
    Burford, ON, Canada
    Okay, so here is my wild guess. There is another set of 901/5x transmissions, but probably sharing the same serial sequence as the "normal" 901/5x series.
    These would be the 901/5xR series, differing in the R&P, with the 8:35 set
  5. #25
    Mark & Gordon, those are both pretty rare and interesting items.
    Quote Originally Posted by 2.5MFI View Post
    I have a 8:35 R&P set for a 901/911 gearbox. Porsche part number 901.332.252.00. I can't find any information on it at all. It's like it never happened, never produced, doesn't exist...
    Mark, I think I've posted this before. It's the only reference I've run across on the 8:35 R&P ratio.
    This is dated Feb 69, but your pinion appears to be dated Nov 66, so quite a bit earlier. And it looks to be NOS... a very nice set!
    Gordon, I've seen this arrangement on a few early 904 pinions too. Is the shaft dated?
    The castle nut was used on the earlier 356-era pinions, as below, so your example is a rare transition between the 356 and 901/904.
    You've got a nice selection of diff shims there too... ;-)
    Jon B.
    Vista, CA
  6. #26
    Gordon, the similar 904 pinion shafts I've seen were drilled completely through, from one end to the other... is yours as well?
    You could drop a pencil through them :-)
    Jon B.
    Vista, CA
  7. #27
    Aug 2010
    Colorado
    Will this work with all 901’s or only a few?
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
  8. #28
    Sep 2006
    Bend, Oregon
    Thanks Jon. And yes it's a NOS R&P.
    Mark Jung
    MFI Werks
    R Gruppe #686
  9. #29
    Aug 2012
    France
    May I ?
    O-G 26 - Early911S 2407
  10. #30
    I think the castle nut pinion was probably 904/906. It was not hollow, and it would work in any 901/911 trans. I also built a gearbox with the 8:35 R&P, not in the 911R’s. The 901/51R was a 911R trans but the other 2 we built didn’t have that kind of pinion shaft.
