Results 1 to 5 of 5
Thread: Rubber hood and engine lid latches
    Looking for another winter project and I am hoping to get some advice. I have searched this and other forums as well as YouTube and surprisingly haven’t found much info.
    I am looking to remove hood and engine latches, associated hardware and internal wires and tubing to lighten my car. I want to replace with lightweight rubber latches.
    Any recommendations on latches? Hood latch looks different (longer) than the engine lid latches.
    Any recommendations on removal of hardware and internal wiring and tubing?
    Any recommendations on installation of the rubber latches so not to screw up the paint?
    S Registry #1229
    1972 Light Yellow 911T (RS look currently, ST replica coming)
    1984 Black/Black RoW 930 Turbo
    2004 Black/Black 996 GT3
    1971 Metallic Blue 911T Sunroof Coupe
    2007 Atlas Grey Cayman S (My First)
    Perfect, thanks Dave. I was on Aase and other sites - obviously not using the correct search terms.
    S Registry #1229
    Are there any videos out there that show the removal of the cable and tubing that attach the hood release handle Inside the car to the latch mechanism?
    I am not sure if I am over-complicating this but didn’t want to start tearing into something without understanding exactly what needed to be removed and from where.
    S Registry #1229
    The cables (wires really) just pull straight out by the knobs once everything is disconnected at the latches. Or they did on my '72, so I'm guessing other years are similar. Removing the tubing would be a lot more work, for very little weight savings.
