Results 1 to 7 of 7
Thread: If You Find Your Pedal Board Has Unraveled
    Jul 2019
    Boston
Size:  111.2 KB[ATTACH=CONFIG]516504 In case it’s useful to anyone, I found a good way to turn a flimsy delaminated and generally unraveled pedal board back into it’s original state and rigidity. See pics below. Just needed the wife’s teapot and some tin foil and some epoxy I had laying around. Steamed it for maybe an hour. Clamped it between 2x4 scraps to let it dry a bit for 4 hours. Then with a popsicle stick size shim scrap I carefully packed expoxy into the many open seams that were then pretty flexible. Clamped it really tight for an hour in 3 sections and in an hour it was as thin as original and rock solid. Just wipe off any epoxy slop from exterior before you clamp
    I cant attach the pics to this for some reason so will do it in steps
    Member #3896
    1973.5 911 T
    1974 911
    1974 CB750K
    Jul 2019
    Boston
    Member #3896
    1973.5 911 T
    1974 911
    1974 CB750K
    That looks like a very fast and easy way to end my marriage!
    May 2012
    UK
    Exactly my thought !
    Aug 2011
    Australia
    Come on it's equal opportunity these days,Chickenstrips is just taking advatage of the kitchen workshop.
    Good work btw.
    S Registry#2021
    Jul 2019
    Boston
    She walked in halfway through the steam session, and I didn't get in trouble. But baking powder coated motorcycle parts in the new oven, is not something I would recommend!
    Member #3896
    1973.5 911 T
    1974 911
    1974 CB750K
    Creative DIY ! ….
