Results 1 to 9 of 9
Thread: 4 Ring Binders
    4 Ring Binders
    I've found these a couple of places but was curious to know if anyone had an opinion on 4 ring binders. I recently picked up all the TSB books from '76-'89. Won't be much help here but I like tech manuals. Make for good bedtime reading.
    Early S Registry #235
    rgruppe #111
    Tech Info Binders
    Porsche made various 4-ring binders for their tech bulletins and service information books.
    You can stack about 6 to 10 years of info into each binder.
    I don't know what's currently available.
    The workshop manuals had the same ring arrangement.
    Jon B.
    Vista, CA
    Quote Originally Posted by Jon B View Post
    Jon B.
    Vista, CA
    Thanks.
    I mentioned it at a dealer yesterday and while the parts person was aware of the use I didn't get much feedback about availability (if any).
    rgruppe #111
    Jun 2011
    Bellingham, WA
    have you tried Office Depot?
    Quote Originally Posted by 72t4tom View Post
    Yes, thanks. If you search they offer 4" Ring Binders.
    Most places don't stock them and I really want to put "hands on" before committing.
    Found a place that does stock some different widths. Leitz, Bindertek etc. Ultimately coming down to
    what can be found for 1-2" widths. The largest manual is 1.5" inches (38mm). The rest are about around 1" (25mm).
    rgruppe #111
    Jan 2007
    Phoenix, AZ
    What you are looking for are A4 4 ring binders. I doubt you will find local unless in Europe.
    I use these...
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    4 Ring Binders
    Your tech manuals should have 80 mm hole spacings. I think most European 4-ring binders are similar.
    The old factory BMW manuals also have 4-ring binders with 80 mm ring spacings.
    A Porsche service manual in a BMW binder...
    Jon B.
    Vista, CA
    May 2011
    Chelsea, Québec
    Europe specific A4 4-ring binder: not impossible to get in US but usually expensive...
    Member #1616
    Readily available on Amazon...
    As an example..
    Leitz 4-Ring 3-Inch Premium A4 Sized European View Binder, White (4287)
    https://www.amazon.com/dp/B002ZXWQ2U..._gvhxEb35SCVZH
    Peter Kane
    '72 911S Targa
