Results 1 to 5 of 5
Thread: 69 911E vapor breather tank (for fuel tank) question
    How does the vapor breather tank pictured attach behind the dash or is it just supported by the attached tubes? Thanks in advance.
    69 911E fully restored
    73 914-6 GT Tribute w/ PMO twin plug 2.7 motor
    73 911 RSR Tribute with Rothsport 3.5 motor
    84 911 Safari build & 88 911 Carmine Red
    90 964 C2 w/993TT motor & 91 964 C2 bone stock 31k miles
    Lightbulb
    No, it shouldn't be.... However many are...
    You see the bent 'U' hanger attached to the upper panel. There should be a square section black 'rubber band' that loops from the 'U' around the middle of the box, and back to the 'U'....
    My square 'rubber band' disintegrated about 25 years ago... so I now use a couple of zip-ties
    I believe some contributors have found close 'rubber band' replacements through some hardware suppliers...
    Pic shows the 'U'.... with no rubber band
    Hope this helps,
    cm
    Thank you Chuck. I noticed the U brackets and felt they were part of the puzzle. Now I know.
    Partsklassik has a nice functional retaining strap that I just used in my 1969 restoration.
    https://www.partsklassik.com/p-1589-...ing-strap.aspx
    Hope this helps,
    Rick
    Thanks Rick, I am ordering.
