Results 1 to 10 of 16
Thread: Braided or rubber fuel line?
    Hello,
    Could you tell us whether #47 and #48 fuel lines from the starting solenoid in the picture were braided or rubber ones when the 1972 911s left the factory. According to Pelican or SM websites, we can get the rubber ones, which are genuine. Im sure these lines were braided ones at that time, as #26 fuel lines on my 911S are braided ones.
    Are there any clamps at each end of #47 or #48 as #26 has clamp at each side?
    If you have any pictures around these lines on an original 911, we would like to see them.
    Thank you in advance.
    Takahiro K
    Cloth braid.
    gled49,
    Thank you for your reply.
    Are these cloth braided fuel lines clamped?
    Takahiro K
    Senior Member 911kiwi's Avatar
    Feb 2003
    Auckland, New Zealand. And Los Angeles, USA.
    Yes, with the special crimped hose clips. Sorry I don't have a photo handy right now.
    Kiwi
    1972 911S
    1967 912
    1959 356A Conv D
    Early S Registry # 306
    911kiwi,
    You mean Norma hose clamp?
    Takahiro K
    Feb 2003
    Quote Originally Posted by silver72S View Post
    911kiwi,
    Takahiro K
    Like this!
    Apologies for poor quality photo - night time here and garage lighting is very average.
    Have not photographed the fuel line from cold start solenoid as the clamps have been replaced with screw type clamps (have yet to get borrow the proper crimp pliers) 1972 911S
    Hope this helps!
    Gary
    Kiwi
    1972 911S
    1967 912
    1959 356A Conv D
    Gary,
    Thank you for the photo.
    I understood which clamps are used.
    Thank you, again.
    Takahiro K
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by 911kiwi View Post
    Like this!
    Hope this helps!
    Gary
    i know those under the name oetiker clambs
    moito,
    Thank you for the clamp name.
    Oetiker clamps are also used for clamping #47 and #48 ?
    Thank you
    Takahiro K
    Takahiro,
    Sorry I'm late with this.... It's all what the others have said... braided lines and crimped clamps.
    Here's from my '2003 rebuild...
    My mechanic set the spacing, cut the hoses, and did the clamping on the work bench. The stacks were eventually mounted on the throttle bodies as a unit.....
    Hope this helps,
    Chuck
