Page 5 of 5 FirstFirst ... 345
Results 41 to 45 of 45
Thread: '73 Fog Light Switch
  1. #41
    Ravi,
    Yes the logic is sound. Thanks for your validation and patience.
    Name:  Fog Fuse Wiring.jpg
    The patina is a little off on the rubber pieces, but the iPhone can see better than the eye in my case. I think the dash looks much better now.
    Name:  New Fog Switch Installed.jpg
    Made a modified Porsche tool P281 to help remove/install the bezel, it worked a little, will need rev 2 if I need to do more removing/installing.
    Think I finally got all the necessary bits to finish the wiring...
    Dave Reu
    Member #3949
    1973 Silver Metallic 911S
  2. #42
    Jun 2012
    London, Ontario, Canada
    Looks great. Should be a useful reference thread for many people in the future, so it was worth the effort.
    Ravi
    Early 911S Registry # 2395
  3. #43
    I am posting in there thread all the Brain Trust seems to be here.
    I bought a rear fog light and fronts, but this question is regarding rear
    Dash has Fog switch.
    I want to connect the rear light to the stock switch and basically have front and rear work from the same switch.
    I got the Kroon rear fog harness and it came with a diagram
    1- I don’t the wire is long enough to reach the switch
    2- trying to make sense of the diagram
    All input is greatly appreciated
  4. #44
    Dec 2010
    Southold, NY
    Here's a text about installation of driving lights that I did several years ago on a 912. Unfortunately Tinypix ceased operation and the images disappeared: https://www.912bbs.org/forum/threads...ion-101.52035/
    Image is of the dashboard after installation of the light switch in the pre-drilled hole originally filled with a plastic plug:
  5. #45
    Feb 2012
    Kolham, Groningen, The Netherlands.
    The white-yellow wire runs from the front fusebox towards the foglight switch (connected to #1)
    Next to the switch you will find a (spare) white-green wire, connect it to #2 ( this wire runs to the left rearlight)
    The brown wire runs from the lamp socket towards ground (chassis)
    The red loop (most likely already connected) on the switch, runs from 3 to K
    The rear foglight can be connected to the spare wire on the left rearlight loom. (the green-white wire)
    If anything is not clear, please contact us at info@kroonwireharnesses.com !
