Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Lightweight SWB: Undercoating or no undercoat?
  1. #11
    Senior Member NickP's Avatar
    Mar 2006
    Solana Beach, CA
    Quote Originally Posted by 911hunt View Post
    At some point this car will be your neighbor on Solana Circle so you can see the final product!
    Awesome! I’m on Nardo. Let’s get together
    Nick Psyllos
    S Reg & R Gruppe
    1973 Euro 911S
    1972 911T to ST
  2. #12
    Quote Originally Posted by Longballa View Post
    Absolutely undercoat the bottom and the wheel wells. You'll regret it if you don't. You don't have to go as thick as the factory did. I do a medium coat.
    After seeing your handy work at Jeff's shop last month I think it is a safe bet to follow your recommendation
  3. #13
    Sep 2012
    Colorado
    My racecar (Note I said "racecar", NOT "track car"), no undercoating. Everything else, definitely at least some undercoating.
    Rich Spritz
    1959 BMC Huffaker Mk1 Formula Junior racecar
    1967 Porsche 911 racecar
    1969 Porsche 911T
    1970 Winkelmann WDF2 Formula Ford racecar
    1973 Merlyn Mk24 Formula Ford racecar
    2007 Porsche 997C4 cab (totaled by an idiot running a stop sign)
    2014 Porsche 991 TurboS cab
    2019 Cayman GTS (wife's)
  4. #14
    You save more than ounces but rather 10’s of pounds.
    It won’t be fully authentic if you don’t exclude the undercoating. None of the factory lightweights had it.
    I have several Porsche’s that came from the factory without undercoating and I drive them on the street, including a 911 werks car.
    However, if it’s not full period authenticity you care about, then it’s up to you of course.
  5. #15
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    A friend once owned 2VEV (Aston DB4GT Zagato) in former times. He made some rubber inserts for the wheelwells as stones picked up by the tread always made dents in the fenders...
  6. #16
    Quote Originally Posted by uai View Post
    The DB4 GT Zagato is alloy bodywork though...?
  7. #17
    Yes, my lightweight was always was noisy when my gumballs picked up rocks from the gravel roads I drove on. However, street driving never caused an issue with noise/dents.
    Undercoat is good for a sports purpose but I was fine without it.
    To each his own.
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
  8. #18
    Senior Member Fubawu's Avatar
    May 2013
    Race cars/track cars remove it, street cars a light layer.
    I mean why not? How fast do you need to get to the car shows? Even with a spirited drive it's worth the added comfort and chassis protection.
    911 1967S 308470
    [B]911 1965 302962 Polo Red
    911 1965 300760 White SOLD
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  9. #19
    Quote Originally Posted by Fubawu View Post
    If you aren't the fastest to get to the car shows then all of the guys in the modern mustangs with straight pipes take the good spots I am leaning towards a light layer of undercoating as many have recommended!
