Results 1 to 4 of 4
Thread: Early fuel tank
    Early fuel tank
    I have pulled the tank from car and realize that it Has a fully round centre hump rather than the later angled hump. I show it next to the new replacement part which does not have this feature. Is this rare?Name:  FF339031-E23A-42E9-B360-F8AA16BE94FC.jpg
Size:  127.0 KBName:  FF339031-E23A-42E9-B360-F8AA16BE94FC.jpg
    Nov 2002
    San Dimas, CA
    The parts catalog shows only one part number, 901.201.010.21 up through '68. Starting in 1969 it gets much more complicated.
    I suspect your car's "round hump" tank is common to all short wheelbase cars (certainly mine), that's several thousand 911s and 912s. I wouldn't call it rare in terms of finding a 911 or 912 with that tank.
    It might prove very rare if you suddenly needed to replace a tank and went looking for one that wasn't in a car.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    Senior Member moito's Avatar
    AUSTRIA (tu felix)
    my theory is that they changed this in order to get the wider wheels more comfortable in and out.... later on they also added a flat surface to the reinforcement bracket under the front slam panel. btw also the breather tube has a wider diameter on your new dansk tank
    Ah. The wider wheels change would make perfect sense for the tank modification! That must be it.
