Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Fuel and oil cap differences
  1. #11
    I contacted ACI with the vin for my 73S and got quite a bit of information. The original registration and plate number. And a chronological list of all the Italian owners and their registrations and plates. This was eight or nine years ago, no idea if they still do this.
    58 speedster
    66 912
    67S
    73S
    97 VW eurovan
    1132 honda snowblower
    member Jackson Hole Ski Club
  2. #12
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    Cees
    For what it is worth here are mine from my Australian delivered (late June 73 built) car. It is pretty much unmolested and still has a lot of the correct date parts on it
Size:  123.8 KBName:  IMG_1172.jpg
Size:  125.3 KBName:  IMG_1173.jpg
Size:  122.7 KBName:  IMG_1174.jpg
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
  3. #13
    The Netherlands
    Quote Originally Posted by steve shea View Post
    Cees did you find a source for the ashtray buffers?
    Nothing so far Steve. Not even sure if there should be a rubber buffer, or one or two. Hope others can chime in.
    Cees
  4. #14
    The Netherlands
    Quote Originally Posted by patrick911 View Post
    Just to confirm Cees, but you probably already knew, my car is an Italy delivered one as well; it still has the different front indicator lenses (more white), no emergency warning lights and a different horn.
    Same here although I believe the first owner has added an emergency flasher plus 4 circuit breakers. The right side door frame has some marks were it looks like people had tried to steal the car. Broke the triangular door window (replaced with tinted glass). Wish I knew the whole story from the first or second Italian owner.
    Famm horns on mine plus two extra in the smuggler box.
  5. #15
    The Netherlands
    Thanks Huw. I reckon the OIL markings were only for the English spoken markets, would make sense.
    Cees
  6. #16
    The Netherlands
    I did some more 'research' and checked all my original PET copies, here the part numbers to each gas and oil cap for the F model:
    PET 1965-68
    oil cap: 644.201.271.06
    gasket: 644.201.272.06
    gas cap: 901.201.271.00
    gasket: 901.201.272.00
    PET 1969-1970-1971
    oil cap: 901.201.271.00
    PET 1972 (ausgabe 71)
    oil cap: 911.207.271.00 (blau B 40 G)
    gasket: 911.207.901.00 (cork)
    PET 1972/73
    oil cap 1972 only tank: 911.207.271.00 (blau B 40)
    gasket: 911.207.901.01 (rubber)
    oil cap 1973 only tank: 911.107.072.00
    gasket: 911.201.272.00
    Basically, until MY72 both gas and oil cap are both the same, definitely no OIL stamped version then. Exception are the 356 parts for the oil cap/gasket.
    Gas caps could have different stamping on the rear. BTW, the gasket for 65-73 years would be rubber?
    It get's interesting in 1973 for the oil cap, different part number and start to believe this is for the single OIL marking. I have a spare 1973 oil tank sourced in the US 10 yrs ago and it has the same single OIL stamped cap.
    Cees
  7. #17
    Dec 2010
    Southold, NY
    Not to confuse things unnecessarily, but here is a picture of an oil cap often seen on the 912:
  8. #18
    The Netherlands
    Another (late) part number I found is 911.107.072.02, double OIL marking and for G model.
  9. #19
    The Netherlands
    1973 oil cap
    Here a pretty original unrestored March 73 911T oil cap. i'll keep the same one...
    Cees
