Results 1 to 10 of 17
Thread: Batteries for a 71 911T
    I started a thread on the Interstate U911's which are discontinued.In one of the threads a member stated that the Interstate
    MTP67R/MTP-T4 fits.Can anyone confirm this 100% without any modifications.
    Thanks inadvance David
    Quote Originally Posted by 71-911T View Post
    I put two Interstate MTP-T4 batteries in my 1970 a couple months ago. There is a flange around the bottom that needed trimming to fit in my battery boxes (which might be deformed due to accident damage), the original tiedowns hold them in place nicely. and there is room for the rubber cover over the positive terminal.
    BruceE.
    Jun 2012
    London, Ontario, Canada
    Good to know there are options. At least here in Canada, the Sonnenschein is slightly cheaper than the Interstate. It does look like the side flanges on the bottom need trimming on the Interstate. They aren't present on the Sonnenschein, but the front and top of the cases look identical.
    Early 911S Registry # 2395
    I just ordered a couple of Sonnenschein @ $185 each. looks like they are quite a bit more than in Canada, wonder why.
    May 2013
    Victoria BC Canada
    Because everything is more expensive in Canada!
    Cheers,
    Jones...
    early S # 2626
    '71 911T
    '05 BMW 330ci
    '22 Wills Sainte Claire
    '96 S10 truck
    Jun 2012
    Yes, pleasantly surprised that they were cheaper in Canada. But so are new Porsches when you convert into USD.
    Dec 2009
    Copenhagen, Denmark
    Just bought two Bosch batteries for $90 each from the local Bosch service center. They were in stock too.
    James Hurst #1638
    R Gruppe #514
    Quote Originally Posted by zenithblue71T View Post
    Just bought two Bosch batteries from the local Bosch service center. They were in stock too.
    Attachment 551436
    Attachment 551463
    Do those fit well? Miata size?
    Dec 2009
    Copenhagen, Denmark
    Yes, these Bosch batteries fit perfectly without any issue. Also fixed a weird starting hesitation I had.
    James Hurst #1638
    R Gruppe #514
    Aug 2011
    Eugene, OR
    Unfortunately, that Bosch battery does not appear to be available in the US.
    - Arne
