Thread: Horn Relay on '66
    Dec 2011
    Monroe, WA
    Horn Relay on '66
    Does or can anyone rebuild SWB ('66) horn relays
    or are new ones available?
    Wil I have to buy a generic 5 prong?
    Peter
    "Fahr drauf, bremsen ist feige!"
    Senior Member mathieulecomte's Avatar
    Dec 2016
    New Jersey
    You can carefully open the current relay you have by bending the four small tabs on the underside and clean yours - it may just be pitted/dirty at the contacts and could work again. Most relay last forever.
    Dec 2011
    Monroe, WA
    Matt, thanks for the response.
    My "current" relay...!
    We did try to clean it,
    I believe it's toast, the magnet won't pull enough to close the points.
    I ended up using a generic Bosch 4 prong with a jumper and mounted it in the same spot. Works great!
    But: Porsche says they have an original according to their catalog. $29.00
