Results 1 to 7 of 7
Thread: Help with a 1969 A/C car
    Senior Member VZ935's Avatar
    Aug 2009
    SF Bay Area
    I have a 1969 911S with factory A/C. After having the AC installed at the tail end of the restoration I noticed the new (thicker) deck lid condenser is hitting the rear, passenger side, air box. I have not been able to find an original (thinner) condenser to replace it with. Does anyone know of a stock dimension reproduction?
    935 Owners Registry #02
    1969 911S, 1970 Euro 914-6
    935 1978
    Copeman Porsche 911 IMSA GTO
    1981 924 Carrera GT
    Aug 2011
    Eugene, OR
    How thick is the one you have now? I'll measure mine tomorrow.
    - Arne
    Aug 2009
    SF Bay Area
    I will remeasure as I don't recall
    Quote Originally Posted by Arne View Post
    935 1978
    1981 924 Carrera GT
    Jul 2011
    Chicago Area
    Thought there was an indentation in that spot on original air box cover for that reason?
    Mike Fitton # 2071
    2018 911S Carrera White
    Sep 2006
    Vancouver, BC
    I have ac that's not factory, but installed in period. It's just under 1" thick or just over 2cm. The entry and exit hoses are on the same end. You have to watch out for where you place the coil, ask me how I know...
    Sep 2006
    Vancouver, BC
    Quote Originally Posted by 69-911T View Post
Size:  73.2 KBName:  IMG_0121[1].jpg
Size:  111.2 KBName:  IMG_0120[1].jpg
    Aug 2011
    Eugene, OR
    The original rear condenser on my '72 factory A/C is about 25mm (1") thick at the most. Some spots measure 25mm, some as little as 23mm.
    If yours is not more than that, I'd look to see if the curvature of the condenser is incorrect. It should fit pretty tight against the underside of the deckled all the way across. I can't imagine much chance that the engine is sitting too high in the chassis.
    - Arne
