Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Throttle Linkage length - 1971
    Dec 2013
    Connecticut/Florida
    I decided to replace my throttle linkage - as you can see from the photo below - it had wear at the rounded tip. After much frustration in getting the set up all correct, I discovered the new one from Pelican/Porsche genuine was over 1/2 inch longer. This makes a real difference, even with some adjustment allowed at the other end. Not sure what is the correct size anymore. I believe I have the correct part number?
    901-423-026-03-OEM - Throttle Linkage, Brand: Genuine Porsche
    Item# 901-423-026-03-OEM
    1971 911S Coupe - Gemini Blue
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    looks like 72/73
    The standard definition of supplied parts these days is "almost fits" we consider them a starting point. My way to shorten a pull rod is to cut to length, then push both ends into a roll pin and weld or braze together. The roll pin acts as a strengthening sleeve.
    Junior Member
    Jan 2024
    France
    Hello,
    I encountered exactly the same problem on my 911 2.0E 1969.
    I bought part 901 423 026 03 on an alternative site, seeing that the length of the trombone side was not good, I ordered it directly from Porsche, and I still have the same problem.
    Has anyone tried with ref. 901 423 026 02 (te ref. for 1968) ?
    Simonjjb, what did you do ?
    May 2009
    Baton Rouge, Louisiana
    If the axle relief “fits” without interference the rod can be shortened by using a die to extend the threads down the rod and cutting off the excess length.
    Gary Cox
    Baton Rouge, Louisiana USA
    1958 356A Speedster, Silver/Black
    1967 912, Aga Blue/Black
    Quote Originally Posted by Xhab View Post
    Hello,
    69's 911E ......very good car
    Quote Originally Posted by garycox View Post
    This what I had to do when I replaced / rebuilt the throttle linkage on my '71E as well. Threading the rod worked but I still need to thread it further to "shorten" it even more.
    Stretch
    Registry # 3063
    Dec 2013
    Connecticut/Florida
    I did the same....
    Junior Member
    Jan 2024
    France
    @Garycox, you're right axle relief “fits” without interference , the rod can be shortened.
    But my mechanic want find the good reference of the rod (perhaps ref.: #901 423 026 02 ? ).
    We are in contact with our local Porsche dealer to find a solution.
    NB: the "old rod" on the photo is the "same" that we bought to our local Porsche Dealer.
    Name:  WhatsApp Image 2024-01-13 at 12.13.04 (1).jpg
    Name:  WhatsApp Image 2024-01-13 at 12.13.04.jpg
    Name:  WhatsApp Image 2024-01-13 at 12.13.03.jpg
    The good part is definitely 901 423 026 02
    Here are the numbers of the 02 part which fits at least for 69's MFI cars :
    Name:  Capture d’écran 2024-01-23 à 13.12.52.png
