Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 59
Thread: Strongest capacity hood struts?
  1. #11
    Aug 2020
    SF Bay Area
    I too used the Rennline on one side, and it worked great holding up my heavy hood + Cibie hood lights. However, I lived in fear of someone, somewhere, sometime pushing it down improperly and 356-ing the hood. I went to stock and added this simple, removable hood support. I forget where I got it (not eBay), but it works for me.
    https://www.ebay.com/itm/324259933844
    - 1969 911T Ossi Blue #3981
  2. #12
    Feb 2020
    NW CT
    I'd encourage getting the correct(ish) hood support:
    https://www.fvd.net/us-en/FVD511RSKI...pport-kit.html
    I've used the long ones and found that the "correct" hood support works better because it locks into the shock towers.
    MBR #3926
    '71 911 T Targa "Rick White"
    '71 911 E "Karen"
    '70 S/T
    '16 CD
    '10 E61 "Vomit Comet"
  3. #13
    Mar 2017
    Orange County, CA & Tucson, AZ
    do they make these types of 'pole' supports for decklids too?
    Bill
    Early 911S Registry Member #4087
    Instagram: @myflat6
    '72T hotrod 210 0228
    '82SC Targa
    '97C4S (sold - and regretting it)
  4. #14
    Aug 2020
    SF Bay Area
    I like that RS style but wasn't willing to drill holes in my hood for this. That's why I went for the bolt on one. I added a (removable) plastic "cup" to the hood to keep the pole from sliding. No issues, no drilling, nothing permanent.
    Found the original place I bought it: https://www.tiporscheproducts.com/pr...fiber-prop-rod
    Per Bill's question: probably no reason you couldn't modify a hood one for the engine lid, if you get creative with the mount.
  5. #15
    Guy on the Bird selling a carbon hood support...fabulous. Never buying crappy hood struts again. Someone can provide the link?
    registry# 1283
  6. #16
    Mar 2017
    Quote Originally Posted by TheTorch View Post
    awesome - i just bought one. i need to figure out the decklid. the Rennline mechanical strut works great (no longer pushing the corner of the lid up/distorting the fitment), but I continue to be worried about someone damaging the lid not knowing how to close it. Even last week at Ed Pink's, the guys told me to put a warning sticker on there somewhere, as they could have easily tweaked the lid by forcing it closed (it is aluminum).
    Bill
    Instagram: @myflat6
    '82SC Targa
  7. #17
    Hi John,
    I'm having the same problem with the new URO shocks I bought. Holds back of hood up a couple of mm. Put the sacked out originals back in and while they do not support the hood, the back of the hood is flush as it should be.
    URO shocks seem to have way too much force, tired originals not functional. What was your solution?
    Mark Peyser
    Easton, CT
  8. #18
    Jun 2013
    lynchburg, Va
    Same issue. Installed redlines. Problem solved Front hood only.
    1969 911S Targa
    1970 911S Coupe
    1973 911T w 3.2
    1972 Alfa GTV 2000
  9. #19
    Thanks. Will give it a try.
  10. #20
    Apr 2004
    35,000 ft
    I don’t really know. So it’s more of a question.
    If strong hood struts are causing hood alignment problems it sounds to me that your hood hinges might have more slop or play than normal. Shouldn’t we consider why the hood alignment issue is occurring besides the strong hood strut showing up as an alignment problem?
