Results 1 to 2 of 2
Thread: Which Cerakote C-Series color for muffler?
    Mar 2016
    Italy
    I'm planning to cerakote my heat exchanger and muffler 'cause I'm tired to spray and respray VTH ... it really do not like rain, wash service water and high heat even if is a good match to the original gray tone. (Also SSI are stainless steel and VHT peel off easily even if primed with the VHT Primer)
    Stoddard exhaust ceramic coat seems to be unavailable (NLA-095-006-01) at the moment.
    Can any one more experienced user tell which color is closest to the original factory gray?
    C8200 and C105 or C7900?
    Aug 2005
    Bucks Co., PA, USA
    I had Shaun at Tru6 Cerakote an aftermarket muffler for me which I asked him to match the original gray as closely as possible. He used a formula of his own making. The result is much closer than using VHT SP104.
    Do note that forum members have had varying experience with Shaun, mainly with turnaround times rather than the quality of the work. My own experience was positive with both. See, for example, this thread: https://www.early911sregistry.org/forums/showthread.php?163295-Be-aware!-Tru6-Restorations-critique&highlight=tru6
    ESR #1474
