Results 1 to 9 of 9
Thread: Help with Drain Plug Position
    Mar 2016
    Italy
    I have removed the oil filter screen and sump plate.
    Before reinstalling I noted that my drain plug faced towards the engine end and between the case split line.
    Looking on my factory manual this is the right position but I see a lot of cars with the drain plug facing on the left side?
    I'm wondering why so many engine has the drain plug on the left and not in middle ... are there any advantage in installing the oil cover with the drain plug sitting in the opposite side of the oil pickup tube?
    here are some photos
Size:  576.9 KBName:  oilplug2.jpg
Size:  155.9 KBName:  oilplug3.jpg
    Dec 2010
    Southold, NY
    Orientation of drain plug is a subtle statement about your political leanings and beliefs; left, right, or middle of the road.
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    Quote Originally Posted by ejboyd5 View Post
    So what does this represent??
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
    Quote Originally Posted by HughH View Post
    Abstain……..
    Peter Kane
    '72 911S Targa
    If you use the the Venturi sump screen instead of the original type, there’s an indentation on the side that you should line up your drain plug with.
    I believe that usually means you have upgraded your oil pump.
    Dec 2004
    Melbourne Australia
    Correct David At least in my case
    Hugh Hodges
    73 911E
    Melbourne Australia
    Mar 2016
    Italy
    Glad to have posted a question that made you laugh.
    So can I conclude that there are no differences (political leanings and beliefs apart)?
    Every manual I've seen places the drain plug opposite the pickup tube, which I believe then places the plug on the left
    John Schiavone
    Connecticut
