Results 1 to 10 of 13
Thread: WTB: '65-'67 Rear Engine Tin
    I'm looking for a 1965-1967 rear engine tin in unmolested condition. It has to have the depressed area on the driver side like the photo below. Send me a PM if you have one.
    JEFF BRINTON
    ESR #1572
    1968 911N
    1974 914 2.0L
    2023 Macan
    SOLD - 1967 911N / 1968 911L / 1967 911N / 1969 912 / 1991 964 C2 / 2013 991.1 / 2008 987 Cayman
    There are 3 versions with the depressed area.
    Which engine carrier do you have?
    Richard
    Quote Originally Posted by preS View Post
    Richard
    Good question.....the one that is currently in the car is identical to the photo that I posted. Mine was modified and cut for a dealer installed A/C system. I since removed the A/C and would like to replace the panel. It's for my '68 911 aluminum case that doesn't have the smog pump.
    JEFF BRINTON
    ESR #1572
    1968 911N
    1974 914 2.0L
    2023 Macan
    I don’t recall exactly, but the hole pattern differs.
    Since you have a 68 you most likely have the later (boxed) engine carrier.
    Richard
    Bump....to the top.
    JEFF BRINTON
    ESR #1572
    1968 911N
    1974 914 2.0L
    2023 Macan
    Feb 2012
    Netherlands, Leiden
    No aff. but is this the one you need?
    https://www.ebay.com/itm/166216414814
    Yes, that's the one....I was hoping not to spend $1,200.00 though....
    JEFF BRINTON
    ESR #1572
    1968 911N
    1974 914 2.0L
    2023 Macan
    Feb 2012
    Netherlands, Leiden
    That I understand :-)
    Dec 2013
    Connecticut/Florida
    $1200! Damn.
    1971 911S Coupe - Gemini Blue
    Senior Member VA_alfa's Avatar
    Jan 2013
    Shenandoah Valley
    I have one in in solid condition but will need paint or powder coat. I’m on the road but can send photos this weekend
    Alex in Virginia
    Looking for:
    ward to driving my car!
    Early 911S Registry # 2863
