Results 1 to 10 of 13
Thread: Best wiper blades 1972 911
    Sep 2012
    Philadelphia, PA
    I’m at the point where I need new wiper blades for Daisy, my 72 T. She has Bosch blades on now, but from early on, I wasn’t happy with their performance. What are you fine folks using on your cars these days? Please let me know when you have a chance..thanks.
    Serge
    Early S Registry #2457
    They don't look right, but I've been using the Bosch Icon beam blade for a couple of years. Best I've ever had, looks like there is a newer version now.
    Easy to switch out for the original type when needed.
    Senior Member rgupta250's Avatar
    Jul 2020
    Orange County, CA
    Depends...are you looking for the best performing wiper blades or the best period correct wiper blades?
    1971 911T/2.45 engine spec Coupe / Gold Metallic on Black
    1995 911 C2 / Guards Red on Cashmere Beige (Sold)
    My brother got tired of the dried out, made in China, Bosch blades and swapped over to some PIAA ones from Tire Rack, https://www.tirerack.com/wipers/deta...3&autoModClar=
    They were tremendously better. The frames look correct and the silicone blade is much quieter. I plan on getting a set for my car as well.
    Joe
    1973 911 2.7mfi
    Early 911 Registry member #759
    RGruppe #499
    Nov 2003
    Santa Monica CA
    mine happen to have the original frames. not the ones with the oval holes you get today. so when it was time for rubber replacement, I found them at my local VW dealer-- they are the exact copies of what is on the car now. the only thing was I had to cut them a little shorter.
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    Quote Originally Posted by raspy2point2 View Post
    Been a while since i had to slide those rubber squeegees into an arm.
    I used the PIAA ones for a while, good blades too, but nothing works as well as the beam type, no matter the speed.
    Apr 2011
    N.Calif., south of SF
    "...bean type..." being the OEM style, VW style?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    I got some from Eric.
    https://www.autoforeignservices.com/
    Craig Williams
    Eugene,OR
    Member #1070
    1972 911E Targa Puck
    Quote Originally Posted by Haasman View Post
    Beam type, is the new design for most modern wipers. I put a set of Bosch Ikon's on. Eric does incredible reproductions and what you want for originality, but for practical on the road use the new design is way superior and seem to last much longer.
    Wipers are cheap and easy to switch out.
    Apr 2011
    Thanks David. Where did you source 'em and did you use just the blades or complete arms?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
