Results 1 to 10 of 11
Thread: 110L Plastic Fuel Tank Question
    Can anyone tell me if the plastic 110L fuel tank used on the Carrera RS 3.0 or Carrera RSR were designed to hold a full size spare or a collapsible? It looks like they could fit a full spare to me, but most pics I have found show a collapsible when they show any spare at all.
    If they do fit a full spare, any thoughts on if a 7" rim with 185 series tire would fit?
    In the spare parts he received with 9114609073, John Byrne had a centerlock 917 rim complete with a collapsible spare tire. Wish I had a photo.
    Peter Kane
    '72 911S Targa
    Wow, those would be 15 x 12 correct? Okay so I know a 15 x 7 rim will work, now I just need to know if it will with the 25.4" diameter...
    Feb 2020
    NW CT
    Photos of Jim Newton's Brunos car, with 110l tank and some serious meat lying on top, which suggests you can fit a full-size spare.
    MBR #3926
    '71 911 T Targa "Rick White"
    '71 911 E "Karen"
    '70 S/T
    '16 CD
    '10 E61 "Vomit Comet"
    Exactly what I needed to know. Thanks. My only worry is that my car is a short hood and Jim's is a long hood.
    Quote Originally Posted by ibmiked View Post
    The rsr no,3.0 rs yes if it does not a oil cooler air duct.Rsr with duct had space saver.
    Thank you.
    Feb 2003
    Los Angeles
    Does anyone know if this plastic fuel tank has any internal baffling or a swirl pot on the bottom?
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
    Quote Originally Posted by Bert View Post
    I dont think so,there is a copper gauze filter in the bottom at the feed terminal,my tank is full of race foam which helps reduce tank surge and i cant see inside it to confirm yes or no.Maybe contact one the repro tank suppliers and ask.
    Feb 2011
    Northern VA
    There is one in my car. No swirl pot built in. Mine runs mfi and I've never had an issue even at very low fuel. I think the shape of the bottom of the tank/entry and return position seems to avoid starvation issues. For a while my triumph gt6 ran on Lucas injection and I had to make a separate swirl pot to prevent starvation under any cornering/not full tank.
