Thread: replacement driveshalfts do they need gasket swb 911
    Jul 2012
    Kent, UK
    hi,
    have just bought replacement driveshafts, do i need gaskets between car a cv joints?
    thanks Rich
    Rich
    68 911S
    mbr. 2393
    Jul 2012
    Kent, UK
    PET shows no gasket
    Rich
    68 911S
    mbr. 2393
    Jul 2012
    Kent, UK
    am re-installing without gaskets , looks like 69 onwards has gasket up to 68 , no gasket on the PET, interestingly for me the failed CV joint had a gasket + recess, wonder if this was the wrong CV joint on the end of my driveshaft?
    Rich
    68 911S
    mbr. 2393
    Early SWB cars with the Lobro CV joints never had a gasket. As a result, they leak.
    So I would recommend sealing the outside of the joint where it meets the flange completely with clear RTV as a preventive measure. If you look at some of the factory photos, you can clearly see the joints are sealed with something on the outside. Some of the factory literature (not all) also talks about using "Mastic" to seal the inside surface of the boots to the flange as well, to help prevent leaks. I found that hard to do with the grease everywhere and still get the clamp on there.
    The RTV trick seems to work OK with my car, at least for a summer's driving. Of course, it has to be redone periodically.
    Mitch M.
    Early 911S Registry Member #3603
    Maryland, USA
    I wrap thin aluminum duct tape around the joint.
