Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Dry Ice
    Senior Member smiles11's Avatar
    Oct 2021
    Northern California
    Dry Ice
    Had my new to me 71T dry iced last month & wanted to share the results. I went through Dry Ice Werks in Grass Valley, CA. Jurgen did an excellent job on the car! He uses a specialized machine from Germany that can dial down the pressure when needed. Delicate enough to be used on touchscreens! He is very aware of sensitive areas under longhood cars. While also keeping as much originality possible.
    https://2shoresdryicewerks.com/
    Before
    Oct 2021
    Northern California
    After
    Oct 2021
    Northern California
    After 2
    Excellent result.
    Dry ice blasting (at higher pressures) can also be used for removing paint. Here:
    (time lapse 4:40>)
    https://www.youtube.com/watch?v=9kHkYrrrP4o
    It's German-speaking but in the settings of the YT vid, the subtitles can be set to Auto-translate to English.
    Jul 2003
    Santa Cruz, CA
    Looks great and effective but, I’ve read that it removes the cosmoline. Looks to be case here. Are you going to have that re-applied for general water protection?
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Michael
    It will if the pressure is dialled up too high but I have had a car done where cosmoline stays intact.
    Depends on the equipment in use and the skill of the user.
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Oct 2021
    Northern California
    Jurgen gives you options. The existing cosmoline coverage wasn’t great which was to be expected. So it’s a personal preference if one believes the cosmoline has run its course. Car is parked on a lift & I’m quite meticulous when it comes to keeping the car clean & protected. I assume coastal weather or northern climates play a large factor to what kind of protection folks use. Luckily I’m in a dry climate & the car won’t see any rain. If it does, the car goes up on the lift & underside can easily be detailed.
    Jul 2003
    Santa Cruz, CA
    Quote Originally Posted by BOYER73S View Post
    Michael
    That’s good to know! When I finish my car, it’s going to get a fresh spray of cosmoline under there. Even though I’m in the same climate. My car WILL see rain when driving, lol.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Oct 2021
    Northern California
    Fortunate to have several Porsche options for inclement weather. I’ll make sure to update how the car is holding up in 10 years / 30k miles.
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    All I can say is that what we find hard to do now is reproduce the quality of the coating ,paint and anodising that Porsche did 50+years ago.
    Mark
