Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 26
Thread: Dry Ice
  1. #11
    Senior Member smiles11's Avatar
    Oct 2021
    Northern California
    Agreed. However it’s a lot easier to reproduce 50+ year worn out protection.
  2. #12
    Here is a setup at a shop near me. It's around $100,000 all-in to include wiring and plumbing. Serious setup.
    Kaeser rotary screw, dryer, air tank, ice box and Cold Jet machine.
    No rookies on these because they can do as much damage as they can do good.
    Early S Registry #235
    rgruppe #111
  3. #13
    Jul 2003
    Santa Cruz, CA
    Further to Tom’s point about monkeys left loose with the toys.. Anyone looked into the possibility of the process causing separation of the undercoating bonds with the sheet metal or microfracturing? I’ve my car completely stripped down and have been considering using this to clean before reapplying black to the appropriate areas.
    The undercoating is in great SoCal condition. Having said that I might opt for a good steam clean with degrease instead. Would suck to find out that the dry ice caused cracking in the original finish only to give moisture the opportunity to get a toe hold,,,
    Michael
    -Dusty 70S Coupe
    -S Registry #586
  4. #14
    Aug 2017
    el sobrante ca.
    you have to be careful with steam clean
    depending on how hot
    and the substrate and finish material (paint)
    you could end up with micro paint checking.
  5. #15
    Oct 2021
    Northern California
    +1
    Skilled hands & equipment with variable pressure settings will give optimal results. Jurgen has done hundreds of AC cars & is well versed. There is zero risk of damage with him.
  6. #16
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    Perhaps you want to listen to that
    https://open.spotify.com/show/6GDAt7h7Z9xpAoTXA9Q3z
    I've learned something and it was quite interesting
    "In this episode Randy sits down with veteran BaT Community member Scott Ales to talk about his network of dry ice cleaning providers across the USA called Dryce Nation. They talk about the new equipment and techniques that are being used on BaT listings to help present underbody and engine compartments in impressively clean detail."
  7. #17
    Not in my experience Michael did a serious blast of the bottom of one of my cars 5 years ago and no issues whatsoever.
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
  8. #18
    Oct 2014
    USA
    What was the approximate cost of this service?
  9. #19
    Oct 2021
    Northern California
    $2500 for underbody & suspension. A little more if you want to do the engine bay. Mine didn’t need it.
  10. #20
    Are you planning to drive the car or just show it?
    If you drive it will return to its former self in a matter of months.
