Thread: WTB: LWB pedal cluster core
    Looking for a LWB pedal cluster that will fit my '71, but I want to tinker with it (I have a working one in the car) so my preference is one that has a solid pan but is otherwise in need of restoration, or just one that will be dimensionally accurate and is otherwise too rough to use. Planning to mostly use it to reverse engineer so I'm not looking to spend a bunch on a good one.
    Sep 2009
    COPENHAGEN, DENMARK
    just for info
    good used ones are hard to find
    https://www.early911sregistry.org/fo...ht=marek+pedal
    Bump,
    The reproduction pedal cluster bases are intriguing, but I still need the rest of the parts to do the reverse engineering I want to do (probably going to do a billet cluster) to understand the stock geometry and then tweak the pedals to make them more comfortable for me.
