Results 1 to 9 of 9
Thread: MFI injection regulator housing
    The Netherlands
    Good day,
    Selling this nice MFI regulator housing. Tested just fine. Asking 250 Euro.
    Regards,
    Cees
    Cees,
    I have a 72T that is missing this part. Is it complete and ready to install? What do you know of shipping to the usa?
    Jule
    The Netherlands
    Hi Jule,
    Yes, it is complete and ready to install, see picture item 38&39. Hose is still available from your Porsche parts supplier. Hose clamp NLA and difficult to find. Shipping is 26 Euro if I can keep the weight below 2kg.
    Regards,
    Cees
    I will take this. pm sent.
    Thank you.
    Kyriakos
    1973 911E Light Ivory
    Cees,
    If above falls through I will take it
    Jule
    May 2012
    UK
    Can be hard to find these they often got ditched I’ve seen photos of quite new cars where was jettisoned early in life. Probably is reason hard to find if those got separated then mislaid
    The Netherlands
    Regulator housing
    This one will stay in the low lands.
    I have another one but need consider to keep or part with it. The PO of my car has removed the themostat and flap and I have driven the car without any issues for the last 20yrs. Starting cold or warm hardly any difference.
    Regards,
    Cees
    May 2012
    UK
    Imo one of those kind of things that might not be essential to have it refitted but still nice to have original (or get one to replace one that’s gone awol).
    One should be kept associated with car. After all they’re not making these any more and the and those extant becoming harder to find. Seem to recall the kundendienst- information of model 72 devotes a whole A4 page to this contraption — a nice line diagram . Unlikely to be sufficient demand to make a reproduction and even if they did new ones probably wouldn’t look right because materials etc change.
    When one is fitted then being very prominent in the engine bay it has to be pukka right down to the correct clip on the right position or it jarrs the eye. I have the original one no fitted but stored with the original rubber trunk and several original clips; plus got another a less smart one with a couple of chips in the plastic around the inlet that’s only good for cannibalising for bits if any workings like flap spring etc were ever damaged in the original . I wouldn’t let these go even if never again gets fitted.
    Just my tuppence-worth
    Steve
    The Netherlands
    The original is still on the car, just without flapper and thermostat. I bought this one a while back because it is complete, just in case I want to mount it as it came out of the factory. In the mean time found another so have a few options. One too many anyway so it will go.
    Regards,
    Cees
