Results 1 to 9 of 9
Thread: Brake Caliper ID help
    Senior Member Gumby's Avatar
    Jul 2006
    Pine Bush NY
    Hi, I have 2 brake calipers that I dont know the correct Porsche applicaiton
    The box they were in only said 'Stoddard 911" I measured the mounts they are 3.5
    any help is greatly appreciated, Thanks Ron
    Ron
    1973.5 911T
    1974 BMW R90/6
    1986 Carrera, Plan "B"
    1987 BMW K100RS Motorsport
    2004 BMW X3 6 speed manual transmisson
    It appears to be a standard A caliper, but I want to see the fluid inlet side first.
    Jul 2006
    Pine Bush NY
    more photos
    Ron
    1973.5 911T
    1974 BMW R90/6
    I believe that is an A caliper that replaced the aluminum S caliper in 1974 on many 911
    Apr 2004
    35,000 ft
    I measured some A calipers I have siting around, these have a spacer that is 6 or 7mm, not the 10mm shown. Possible these are later, like from a 84-89 Carrera with thicker rotors?
    Yes, you are probably correct, I was thinking of the 10mm spacers on the 911 rear, but the 911 front with 20mm rotors use 7mm spacers. This is a wide A caliper then.
    Jul 2006
    Pine Bush NY
    I remeasured the spacer and it is 7mm, in the photo the '10' is to the left of the actual line, seems like they are for 74-83
    Thanks for the info guys, so they will not work for me : (
    Ron
    1973.5 911T
    1974 BMW R90/6
