Results 1 to 9 of 9
Thread: Recommissioning of Biancaneve
    Dear all, following years of hard, sometimes reckless use and abuse of "Biancaneve", our '73 2.4S, we have just completed her recommissioning.
    I'd like to share here some images and stories, hoping you will find them interesting.
    Instagram
    Twitter
    This time the work looked complex and we wanted to have it finished soon and well, to enjoy the springtime events ... therefore, we entrusted the work to a central-european specialist, who doesn't want publicity so we won't name him. Those who know, they know.
    We started with refurbishing and re-wiring the light switch.
    Instagram
    Twitter
    Feb 2003
    Los Angeles
    Looking good so far. What is on your To Do list?
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
    Do you have a way of replacing the dimmer rheostat?
    Quote Originally Posted by Bert View Post
    Safety and performance oriented, including but not limited to:
    - Rewiring electrical connections: replace faulty units
    - Replacing oil and fuel lines, where needed.
    - rebuild front calipers and replace rear ones;
    - engine-out check and replacement of sealings, etc
    - check-measure-repair engine accessories
    - replace driveshafts, wheel hubs, suspensions bushes, etc
    - replace or repair countless small items.
    Everything OEM or better items, must keep period correct appearance.
    Instagram
    Twitter
    It was rebuilt by one of the workshop guys ... not easy, apparently ..
    Instagram
    Twitter
    Jun 2012
    London, Ontario, Canada
    Old ladies need to go to the spa once in a while. Looking good!
    Ravi
    Early 911S Registry # 2395
    Here is a list of the spare parts:
    o-ring termostat 99970731440
    seal for cover 93010519507
    seal for cover 93010519404
    oil hose 90110734703
    oil hose 90110734803
    intake hose 91110723300
    hose clamp 99951209100
    oil hose MFI 90111004103
    oil pipe 91110772420
    hose choke 00004320521
    hose vaccum 9991800935A
    pressure line 91135606614
    fuel line 91135606408
    heat control box L 90121100723
    heat control box R 90121100823
    hose control box red 93021162201
    seal for control box 91121129700
    heating hose 90121119401
    flex hose 91110815100
    flex hose 91110632900
    seal 90111119300
    seal 93011119113
    seal shifting 91142429400
    wire pull 90142470107
    guide 90142470402
    housing 91142308102
    seal gas 91142359301
    screw bolt 91142322701
    bearing bush 91442321101
    pull rod PCG42301600
    seal clutch 91442392202
    lever clutch 91142320503
    driveshaft 91133203309
    sealing driveshaft 90133229700
    blower fan 91157132032
    gasket 90157192201
    windscr. jet valve 91462821500
    windscr. jet 90162874120
    oil filtr 93010776403
    fuel filter PCG11090910
    air filter 90110895511
    complet fuel hose
    oil 20w50
    gearbox oil
    brakefluid
    taper roller bearing inner 99905909800
    taper roller bearing outer 99905906500
    gasket set front brake calliper 90135199800
    rear brake calliper 91135290700
    seal front wheel hub 477405641
    piston front brakecaliper 90135198800
    brakepads 91135295006
    sealing engine place 91150411500
    sealing engine place 91150411102
    rear bearing oversize 9990530530A
    cap 91461349100
    rubber grommet 91450431900
    cover shifting 90142429202
    cover 90161131300
    protective cap 99965900650
    cover tacho 90174129100
    banjobolt 90135553100
    banjo 91435553100
    snap ring 99915200400
    sealing camshaft 99911306850
    sealing crankshaft 99911305752
    pulley sealing 99911329041
    seal 93010519801
    Alu washer 8,4 90003101430
    Micro switch 90161310600
    seal 93010779102
    cable holder 90160959100
    line holder 91611033000
    bracket 90150193022
    protective sleeve 90120159121
    relay for injection pump 90161511101
    connector housing 91161211502
    cap 99965243640
    pin 99965237612
    sleeve 99965216040
    pin 91161290701
    pin N0174982
    wires
    wheel repair, balancing …
    zinc parts
    Instagram
    Twitter
    Next step was to attack the ventilation fan ... another usual victim of the time, displaying erratic functioning.
    Instagram
    Twitter
