Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Another pedal cluster question
  1. #11
    Not sure ….but the video appears to show the moving arm is hitting the floor ?
    You can see the unit moving up in vertical position & down when rotating…
    May be some work on floor or can unit be shimmied up slightly?
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
  2. #12
    No, that is excessive play, never seen one worn that much. Time to look for good used cluster.
  3. #13
    Had my cluster repaired...
    The result is perfect !
    https://www.youtube.com/watch?v=BXqp0rBb_sE
  4. #14
    Quote Originally Posted by 71gold View Post
    Floor bolts were not tightened on that first video.
