Thread: Door card edge plastic trim pieces
    Does anyone know if you can buy the plastic trim pieces that go on the vertical edges of the door cards I am missing a couple on a car I am retrimming.
    If not guess a discarded door card may still have them attached.
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    The Netherlands
    Hi Clyde,
    I doubt it is a separate part you could order, best to find and old doorcard. If this one will help you, just have this spare right side, let me know.
    Regards,
    Cees
    Quote Originally Posted by fourteenten View Post
    Hi Clyde,
    Regards,
    Cees
    Can you believe it cars but Appbiz make a perfect replica and it’s cheap have to cut of course but awesome it is available
    I did find one down under too thanks
    Clyde Boyer
    The Netherlands
    Good to know that Appbiz reproduces them. Thanks for the heads up.
    Regards,
    Cees
