Thread: Flasher Kaput, electronic not working properly
    1970 911 E original transistorized turn signal and hazard flasher stopped working. Bought generic 4 prong electronic flasher to replace and getting weird behavior, namely both dash indicator lights flashing with left or right signal. Do I need a more specific flasher to the 911? On the bench, I can make the flasher work, but terminal C seems non-functional as a positive or negative terminal. In the schematic, it looks like C is providing ground to the dash indicator lights.
    Member McOtto's Avatar
    Apr 2023
    Denver, CO
    Welcome to the forum. The attached link chronicles my experience with the flasher relay on my ‘72
    https://www.early911sregistry.org/fo...1-Flasher-Unit
    1972 911T Targa
    1985 911 Carrera (with circa 1988 RUF 3.4L 260 hp DIN Engine Kit)
    Thanks. I was thinking all 4 prong flashers with the 31/49/49a/C terminals were the same. Apparently not!
    I ordered a flasher from Zims that they said works just before reading this thread. If it doesn't, I'll try the modified Novita. I actually was trying the stock Novita now and while it works, there's odd behavior, mainly that both dash indicator lights flash when either left or right turn signal is activated.
    Do you know if the dash indicator lights illuminated when the hazard switch was engaged? With the stock Novita, mine don't, but the red hazard switch light does.
    Apr 2023
    Denver, CO
    Quote Originally Posted by thelews View Post
    I was thinking all 4 prong flashers with the 31/49/49a/C terminals were the same. Do you know if the dash indicator lights illuminated when the hazard switch was engaged?
    For 4 prong flashers, the difference is in the C terminal function. On the Hella TBB3 Porsche originally used, C terminal is a pilot. The attached wiring diagrams are for a ‘72. During my troubleshooting effort, I marked them up to help me understand device and circuit functions.
    On your question regarding the dash (turn signal) indicator lights, no, they should not blink when the hazard switch is engaged. Only the hazard switch light should.
    1972 911T Targa
    Sep 2018
    Netherlands
    I went through a similar problem, see post #7 here:
    https://www.early911sregistry.org/fo...ght-is-buzzing
    1970 2.2S Elfenbeinweiss
    2002 996 TT Midnight Blue
    Member #3833
