Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: torques
  1. #11
    pwd72s
    Guest
    Re: torque wrenches
    Thank you for the website and the number thu there. Believe me, I WILL check it out.
  2. #12
    911SRegistry
    Guest
    Re: torque wrenches
    All "click-type" torque wrenches need to be calibrated for accuracy; and even then, their accuracy may be only +-2-5% depending on the quality. When was the last time you had your T. wrench calibrated?
    The most accurate, though less convenient to use, are the beam type torque wrenches with the needle that deflects and reads directly onto the scale. To calibrate, you simply bend the needle to read zero when the tool is at rest.
  3. #13
    pwd72s
    Guest
    Re: torque wrenches
    Not to mention that the beam types sell for less. Thanks for mentioning it. Not every torquing situation allows you to keep your eye on a beam wrench needle, but most do...really, thanks. This might be the best answer, for my purposes anyway.
