Results 1 to 5 of 5
Thread: parts view of 68 door panel to look at?
    Its time to finally begin putting the interior back in my 68 912 and I honestly dont remember what allens went where on the door pulls. This is the first SWB car I have done, and I need help. Anybody have the parts book page? Thanks, Bill
    Bill Woods
    S Registry #1005
    I think the two long Allens are at the front, with the short one in the back, but you better get a second opinion on that because my memory is not 100%. Prepare for a bit of a fight with the door pockets...you have to blindly find the screw holes in the door while the pocket is fighting the screwdriver for the same space. So, what color is your '68?
    Dec 2008
    Black Mountain, NC
    Also take note of the screws mounting the pannel the SWB has a screw in line with the door lock pin (pull whatever you call it) there should be 1 screw shorter than the others, it gos there or the lock will appear jamed.
    Member 1488 MrJTP2001's Avatar
    Nov 2008
    Denver area
    Bill, you have a private message. (maybe 2)
    Tony
    68 Sporto Project
    2016 Boxster
    Hi,
    In case a pic helps, here is an all original 68 door (dated 28.9.1967)
    HTH
    Alan
  1. RS Door Panel; Strap Door Opener
    By Captain in forum Technical Info
    Last Post: 03-15-2022, 09:48 AM
  2. FS: 68 door shells no rust, 67 pass door panel/arm rest, fuch rims
    By scwhite59 in forum For Sale: 911 Parts
    Last Post: 08-14-2013, 04:31 PM
  3. Replies: 2
    Last Post: 03-09-2013, 02:27 PM
  4. Door top bolsters -- upper door panel trim - 69-71
    By Eminence Gris in forum For Sale: 911 Parts
    Last Post: 09-11-2011, 09:13 AM
  5. OEM Door Rear View Mirror?
    By RTincher in forum Technical Info
    Last Post: 12-27-2005, 05:51 PM
