Results 1 to 10 of 20
Thread: Rear Sway Bar Drop Link Question -
    Hey guys, I just picked up my "new" 69 911S yesterday and am spending some time today going through the car. In about 100 miles of spirited driving yesterday I noticed a clunck from the drivers side rear every so often. It definitely sounds suspension related. On looking under the car, I see that there are 2 slightly different drop links for the rear sway bar. Sorry for the poor pic quality - but here goes:
    The passenger side is the first 2 pictures and the drivers side is the second 2. As you can see, the passenger side is a stud that goes through the the drop link and is attached with a nut, whereas the drivers side is a bolt that goes through. Which is correct and could the drivers side link be clunking?
    On a totally unrelated note, when I put gas in the car I somewhat overfilled it and the cabin is filled with gas fumes - is this normal?
    I'm no expert on P-cars, but this looks like an aftermarket swaybar set up. The nut and bolt shown in the second set of pictures looks like it replaced a broken ball stud, thus eliminating the generous gap between the bar and link. This lack of clearance could be causing the clunking sound. A longer bolt and a steel spacer from OSH should restore the clearance.
    Regarding the gas smell issue. Check your gas cap to see if it has some kind of a gasket that seals against the filler neck. I had the same problem on my 72T, and that's after replacing the six miles of vent hoses in the trunk. The cap did the trick - or more accurately, putting a gasket in the original cap.
    Leaf green 72T, SOLD!
    Gone back to my MoPar roots!
    Thanks Alex - I thought the same thing about the spacing with the odd looking bolt. As for the gas smell, I think I found the culprit. The rubber hose that connects the filler tube and the tank was loose and when I filled the car I topped it off and the fuel level was right below the filler cap - so a fair amount of fuel must have leaked out into the truck.
    By the way, this is my 7th 911. I have owned 2 87 Carreras, a 993 C4 Cab, a 993 Twin Turbo, a 930, and a 71T track car. I must say, other than adding creature comforts, I do not see a lot of improvement in the 911 series from the 1969 S. This car's gearbox shifts like silk - perhaps the nicest 911 gear box I have driven. The clutch feels great, the steering is light and precise, the handling is very good - not too far off from my track car - at least in moderate street driving, etc, etc.
    I always wondered if the newer cars were really much better, and if so, how much. My 72 was affordable at the time plus I like the early body style. My thought is to update it with newer car stuff, such as seats - and like you said "the creature comforts"
    The S should have a ball joint at the arrowed point on the swing arm. The factory AR bar drop link attatches to it
    Hey Nick - this car originally had the "Hydropneumatic" suspension so I don't know if that makes any difference. From looking at the owners manual (very cool manual with lots of info on DIY maintenance) I see no mention of a stock rear sway bar. It does show the front sway bar, but no rear bar is shown in any of the diagrams or mentioned in any of the text.
    EDIT - I did find mention of a rear stabilizer bar in the manual. This car had the suspension changed out years ago to replace the hydropneumatic struts. It also went through a bare matal respray. I wonder if the rear control arms were replaced with arms that did not have the roll bar mounts on them??
    Anyone know where I can get the correct sway bar and mounts?
    An S with Hydropneumatic suspension? I haven't head of that one before. The ball joints are available over here in the UK and may even be available from a Porsche dealer as they are shown in the PET "for subsequent installation"
    Quote Originally Posted by nick-moss
    Yep - you kind of wonder why you would order an S with that suspension, but it was an option in 1969. So I assume I could just drill a hole and tap inot the arm for the correct mount? This is the way the rear factory drop links are mounted on my 930, so I get the general idea. Thanks for the help.
    I think they are welded rather than tapped, but still an easy job with the bananas off the car
    Nick, I had some arms with and some arms w/o. The arms with also had a reinforcement piece in the arm for the ball. I think it would be easier to swap arms if you have to take them out as well as find the second piece. Just my .02.
  1. Rear sway bar connection to drop link...
    By KenJ in forum Technical Info
    Last Post: 12-27-2013, 11:59 AM
  2. 73 carrera rs sway bar drop link bushing
    Last Post: 06-29-2012, 12:54 PM
  3. Weltmeister Rear Drop Link 22mm - where to find?
    By karlusmagnus in forum Technical Info
    Last Post: 05-13-2011, 09:27 AM
  4. Front sway bar drop link installation
    By mcaterino in forum Technical Info
    Last Post: 05-19-2010, 11:29 AM
  5. FS: Rear sway bar drop links for an SC
    By EA911 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 12-30-2009, 03:01 PM
