Results 1 to 10 of 12
Thread: Scored a large displacement MFI setup
    I posted this over at Pelican, I hope its ok to do this. Any help is appreciated.
    What do you guys think this was from originally?
    Intake port orifice measures 39mm, the top of stacks are 43mm. Everything was covered in dust, but it cleaned up nicely. The pump turns over smoothly by hand and the throttle plates all move smoothly and freely.
    I know that the '73S shared some part numbers with the 2.7 and 3.0 RS cars on the MFI setups. Is there anyway to tell if this came off of a 3.0 RS without disassembling the pump and looking at the spacecam? Can you guys tell from the serial numbers?
    TIA
    #711 - expires 12/05
    1972 911T - Sepia 3.2 - For Sale
    #019 is a 2.7 RS Carrera pump tag ... Not sure if they kepted the same pump through the 3.0 Carrera.
    Jun 2003
    2.8 rsr
    Chuck,I think you bought one of those carrera M491 spare parts list from me on page #20 the injection pump # is 911 110 222 072
    I did indeed Frank...
    However,
    Your 911. part # is Porsche ... and my .019 part # is Bosch...
    Thanks guys! I apreciate the help.
    Ok, heres the $64k question:
    Can I use this on the motor Im rebuilding without re-camming the pump?
    My motor is a 3.2 Max Moritz short stroke with GE40 cams. It was setup with small port SC heads and 40mm webers in its previous life and it was known to work very well.
    I didnt want to change a lot of things on the rebuild becasue it was setup well, but I want MFI. This means I need bigger ports if I use these RS throttle bodies. I know it will function, but will the 2.7RS pump work well with my 3.2 and GE40s if I find a set of heads with 39mm intakes?
    TIA
    Card carryin' member! mjmoran's Avatar
    Aug 2003
    Late 1972...73 RS
    There is a date stamp for Dec (week 52) of 1972 on the pump, so I would guess either a 73 S or RS
    Michael
    72 911S Coupe, Sepia Brown
    Ok, I know the probability that this came from a 3.0 RS is less than good. How can I tell for sure?
    The port size is whats throwing me off. The RS had 36mm intake ports, these throttle bodies are setup for 39mm. I cant tell for sure that they have never been bored out, but I'd be willing to bet they havent
    I know the 911/77 motor used the 2.7RS MFI setup and that the cars were only built (in very limited numbers, none of them in the US) to homolgate the 3.0 RSR for racing.
    That setup was a great find. I might think about having the pump freshened no matter what because how will you know what you are working with? You can give the pump rebuilder the displacement, compression, port sizes ect. that he will take into account when doing the pump.
    Hans at H&R here on Long Island did my pump with the above information and it did not even need adjustment once installed. It is not a big expense either compared to doing the stacks which you may also want to do. MFI is great when all is working properly which usually means fresh not worn components. Good luck.
    Best,
    Don
    Rsr Mfi
    Shuie,
    Chuck is right, the pump number is a 2.7 RS pump number. Those throttle bodies appear to be ported standard MFI, as like on Dick Moran's 2.9 motor. In theory they should not fit (mount on heads) on a 3.0 or bigger engine, try to fit them up and see.
    PM me if you other questions as I have all my reference material at work and I can find out just about any info you need. Hope this helps.
    All the best!
    Roger
    R Gruppe #27
    Thanks Roger! I appreciate the help. PM on the way.
  1. Did I mention I scored these...
    By Fishcop in forum Australia
    Last Post: 04-13-2013, 09:15 PM
  2. Somebody scored!
    By pelon in forum For Sale: 911 Parts
    Last Post: 06-13-2012, 03:03 PM
  3. Replies: 0
    Last Post: 06-10-2008, 02:16 AM
  4. Displacement Stickers?
    By Schläfer in forum General Info
    Last Post: 12-01-2006, 11:56 PM
  5. Who's the lucky guy who scored the 67S case
    By gruen911 in forum For Sale: 911 Parts
    Last Post: 10-23-2005, 08:43 AM
