Results 1 to 10 of 16
Thread: What do you do about clamps (or, calling the clamp police)
    I'm in the process of removing any and all worm drive hose clamps (especially the cheap perforated ones) and replacing with recycled OEM Norma clamps that I have had gold zinc'd at the plating shop. In some places, I have found Gemi clamps that are gold leading me to believe that Gemi (a German company now owed be the ABA clamp company) was an OEM suppier along with Norma Schelling.
    I have found only one source of gold zinc'd Norma clamps and they are super expensive. I mean 5 bucks a clamp for a fuel line size of 12-16mm!! The source (which comes up on Google with a search for "Norma clamps") has the clamps imported and plates them here in the USA according to thier info.
    I can do better, I think. But here's what I'd like to know, is Gemi an OEM and acceptable clamp for the restoration and performance community? If I buy these by the gross and have them gold zinc'd, will ayone buy them?
    Here's a couple of links to help you see the merchandise (the 2nd one is a .pdf):
    http://www.abagroup.com/
    http://www.abagroup.com/upload/Catal...ures/Ultra.pdf
    BTW, I can get and plan on supplying the correct original fillister head slotted metric machine screw with the clamp for the purists. The performance minded would probably keep the hex head and torque accordingly.
    Milt, I'd buy some as spares...it would take a really critical eye to know the difference, once they are gold zinc. How many different sizes are there on a 911? I dunno...but maybe a compartmented plastic box, sold like the fastener assortment boxes you see advertised?
    Milt,
    I being resourceful, have you considered wandering through the dead car graveyards? Namely Pic-A-Part. If you have a large enough quantity of clamps to upgrade, it might be worth a trip to scavenge the Norma clamps found on the various Audis, Saabs, VWs, Volvos and whatever, then have them replated. At $5 a pop for new ones, it wouldn't take that many to offset the few bucks the bone yard and the min. a plating company will charge.
    Sherwood
    Clamps-more info
    if youre not too concerned about absolute originality, the Norma clamps are available in silver zinc from Wurth, and for much less than $5.
    I am sure that the other company has them stripped and plated to the gold zinc color which accounts for their $5.95 cost! I think these clamps are around 1.25 each or so retail, so even with plating, they are still pretty proud of their clamps. I stock these at my shop, but any decent German/Import shop probably stocks these as they're OEM on older BMW's also, except the silber is correct for those.
    Many grip ranges and band widths are available, and Gemi clamps are also available..
    Matt McGinn
    SportsCar Restoration
    Dec 2002
    Birmingham, MI
    It's time to revive this thread! I'm in the market for all new hose clamps and want to know if there is an less costly alternative yet to the Eagle-Day $5.95 each, cad plated Norma clamp. C'mon, there must still be some clamp police on the beat??
    http://www.eagleday.com/normaclamps.html
    Jared
    '73 911S #0793
    '69 912_ #0602
    Early S #0454
    RGruppe #0391
    Norma clamps should be found with a search on the internet. However, they're not yellow zinc plated. Someone would have to buy enough to have them plated. If no one wants to buy a bunch, then foot the relatively low cost for plating (not CAD, btw), that's why EagleDay is doing it and charging for it as well.
    Sherwood
    I buy mine at the local Wurth shop and plate them gold zink, not expencive at all.
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Sunshine State
    Jared - I've got 13 Norma clamps on my fuel line setup. 13 x $5.95 =
    Pony up the money bud, it's a drop in the bucket compared to your overall bill!
    Whats the difference between gold zink and cadmium plating?
    Erick
    W/o the chemical talk, zinc coating uses/creates less hazardous chemicals than cadmium plating. Cad plating lasts longer; costs more. Due to the above, there are fewer places that offer cad plating services.
    Sherwood
  1. H1 vs. H4 - Calling Light Police
    By jaudette3 in forum Technical Info
    Last Post: 09-11-2012, 06:26 PM
  2. Calling all Fuch police
    By popowitz in forum Technical Info
    Last Post: 09-05-2011, 06:37 PM
  3. Calling All Pedal Police
    By Paul Schooley in forum Technical Info
    Last Post: 08-19-2008, 03:33 PM
  4. Calling the Seat Police
    Last Post: 05-01-2006, 04:33 PM
  5. Calling the Fog Lamp Police
    By Sacto S in forum Technical Info
    Last Post: 03-24-2005, 10:25 AM
