Thread: Need your advice. Will this dizzy work???
    Hi All,
    I just finished rebuilding my 2.2l Tengine. Only thing left is replacing the old Marelli distributor with a Bosch one in order to be able to replace the cap & rotor. My Marelli is still ok, but as you all know Rotor's & Caps are hard to find and/or extremely expensive.
    According to different sources, for my 1971 911T I would need a 231-159-008 bosch dizzy. These are hard to find. I am able to get these parts:
    231-159-006 (For an E)
    231-159-007 (For an S)
    Would these parts work on my engine? I guess the gear on all of these dizzy's are the same, since they are coming from the same engine type. Does it matter that the E & S use MFI instead of carbs? Probably there's a difference in curve.
    Thanks for educating me!!!
    Hessel
    911 E distributor great
    Hello: I would use the E distributor on your T they work great with a great advance curve and very driveable. I have out these on 914-6's and 911T's as well and they are great. Good luck with your project. Thanks Eric
    in the market for a 997
    May 2007
    Reviving and old thread here as I have a similar issue.
    I'm replacing a Marelli on a '71T.
    I've got my hands on a Bosch 007(S) distributor.
    Wondering about compatability given the different advance curve.
    Found this advance graph for E & S. Anyone know how this compares to the T (008) distributor?
    Thanks!
  1. WTB: 2.2 E cams and dizzy
    By xpensivewino in forum For Sale: 911 Parts
    Last Post: 01-07-2013, 05:30 PM
  2. need a guy to rebuild my dizzy
    By Boulder Bob in forum Technical Info
    Last Post: 10-13-2010, 01:47 PM
  3. Re-Curve Dizzy
    Last Post: 05-20-2010, 06:06 AM
  4. WTB 2.2 E or S dizzy
    By 356robo in forum For Sale: 911 Parts
    Last Post: 04-17-2009, 01:52 PM
  5. Dizzy Help
    By Carrerax in forum Technical Info
    Last Post: 01-20-2009, 08:48 PM
