Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: MFI cold start proceedure w/ cold start disabled
  1. #11
    Thanks for all the responses. I guess the best thing to do would be
    to install a "manual cold start button/switch"
    Took a road trip to Taos & Santa Fe, NM this last weekend, total r/t of
    about 600 miles. Anyway the 1st morning car was a real bear to start.
    A little better in Santa Fe, but nothing like the descriptions of ease of starting
    here.
    1973 911E Viper Green
    2021 Spyder PTS Signal Yellow
    2019 Carrera T Racing Yellow
    2008 Boxster S Ltd. Ed Orange
    2007 911 GT3 Meteor Grey
    @Type911 instagram
    RGruppe #295
    Zuffenhausen secret weapon
  2. #12
    Cold start
    Replace the thermo time switch and check the pump accuator. The thing should work fine, forget the aux switch. Read the manual on how to trouble shoot the system, it is simple.
    Jeff
  3. #13
    Quote Originally Posted by schmidt
    Jeff
    Jeff
    thanks for the reply. I have the CMA manual. Will look into your suggestions
    Had my Porsche Tech
    adjust mixture, as car came from sea-level...was running about 13% !
    Was adjusted to about 4% at 5000 ft. (ABQ where my shop is)
    Iam at 7600 ft elev, would this be contributing to these symptoms at all?
    @Type911 instagram
    RGruppe #295
  4. #14
    Your mechanics technique is right on with holding to the floor on a warm engine and letting up slowly. That altitude shouldnt matter, the trouble shooting test should be performed and you will figure it out. Last year I had a 75 Euro carrera I bought and the guy never fixed the cold start, I ran the checks and came up dead. No power to the system, turns out the relay was no good. You really need to have the spares of the system to diagnois and repair. You cars sounds exactly like a car that is not getting any fuel when started.
  5. #15
    Run a meter to the cold start fuel switch at the top of the fuel filter console. On a cold engine as the key is in the cranking position the meter should show 12 volts for 5-7 seconds as you are cranking, and as you keep cranking without letting up at the end of the 5-7 seconds the meter will go to zero. On a warm engine this feature is disabled by the thermal time switch, no allowing any fuel to pump. Try this first and tell me what you get.
  1. 73.5 CIS cold start
    By Mac911 in forum Technical Info
    Last Post: 04-23-2024, 12:57 PM
  2. hard cold start
    By robmog in forum Technical Info
    Last Post: 05-07-2012, 06:12 PM
  3. cold start solenoid
    By cmcfaul in forum Technical Info
    Last Post: 04-24-2011, 05:12 AM
  4. cold start problem 71T
    By super9064 in forum Technical Info
    Last Post: 06-04-2007, 08:57 AM
  5. 73.5T cold start
    By Gumby in forum Technical Info
    Last Post: 08-11-2006, 09:31 AM
