Results 1 to 8 of 8
Thread: plastic mfi intake trumpets
    Are all plastic intake trumpets the same diameter and fitment? For example, would a set from a '71 911E be correct for a '69S?
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Quote Originally Posted by kenikh
    Hi:
    E & S intake trumpets are different sizes so you should use the S ones for your stacks.
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    Pre- '72/2.4 were mag stacks
    '72 - '73 / 2.4 - 2.7 RS Plastic stacks were different according to their throttle body size
    Plastic Stacks R/L
    S - RS 911.110.063.02
    E - 911.110.065.02
    T - 911.110.071.02
    Hope this helps
    More stuff for a "best hits" section on the board! Any chance to add a section, Chuck?
    Peter Kane
    '72 911S Targa
    Not stacks...TRUMPETS
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Kenik,
    I think we're having a problem with semantics...
    Look at the 2 pics and let us know what part you mean...
    Fist pick is of a '69-'71 ... Throttle body, mag 'stack' (actually called suction pipe) and small velocity stack within the air cleaner (unique to '69-'71)
    Second pic is one side of a 2.4 plastic 'suction pipe' assembly ... molded in one piece
    Please stop yelling... we're trying to help
    Cheers,
    Trumpets not stacks!
    Hello: He is talking about the trumpets (ram tubes,etc.). The trumpets are different sizes for the T,E,S. If you have S stacks use the steel trumpets from PMO or one of the carb places. The old plastic trumpets get brittle with age and if you get a back fire they melt. Now for the stacks, yes the early ones are magnesium(69 are different) and the late ones are plastic with the trumpets built in. The late plastic ones melt also on a backfire. Hope this clears this up. Thanks Eric
    Trumpets
    The 69 trumpets only are 50mm at the trumpet, the 70-71 are 46mm. One the S only.
    Jeff Smith
  1. What cleaner for plastic intake runners MFI ?
    By majordad in forum Technical Info
    Last Post: 12-17-2013, 08:15 AM
  2. WTB: Plastic air cleaner intake housing for 73 911 with MFI
    By Haasman in forum For Sale: 911 Parts
    Last Post: 05-25-2013, 10:27 AM
  3. WTB for 67 - intake trumpets and SSIs
    By Alan B in forum For Sale: 911 Parts
    Last Post: 08-01-2010, 10:29 AM
  4. fs: Red Plastic Air Intake Stacks for RSR
    By garyz in forum For Sale: 911 Parts
    Last Post: 06-17-2009, 10:58 PM
  5. Looking for a set of 3 MFI intake trumpets(?)
    By bobmagyar in forum For Sale: 911 Parts
    Last Post: 12-12-2005, 09:23 PM
