Results 1 to 7 of 7
Thread: 1970 911S compression numbers
    What are the range of acceptable numbers [LBS] for a cylinder compression test.stock 1970S
    if I am not mistaken it would be around 175 and all cyl. should be +/- 10 of each other
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    My '69S had 125 psi across all cylinders, with less than 6% leak on all with variance of 2% max. Were the 2.2S that different?
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    I could be wrong as I was going by memory but that is always suspect.
    The reason I ask is I got 135 lb to 140 lb on all cylinders.I can't find the specs on this in any books.
    Figure c/r is around 10:1 should give 14.5 psi x 10 = 145 psi, doesn't always work out that way with radical cams etc.
    Phil
    135 to 140 on all would be good, no problem especially being it has some miles on it
  1. 1970 911T Compression Gasket Problem
    By thilmes in forum Technical Info
    Last Post: 01-19-2014, 10:58 AM
  2. matching numbers 1970 911T
    By davewadd in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 08-22-2012, 04:25 PM
  3. 2.2T compression/leak numbers
    By jetdriver21 in forum Technical Info
    Last Post: 12-30-2007, 11:16 AM
  4. what should compression readings be 69 911s?
    By blucille in forum General Info
    Last Post: 05-25-2005, 07:07 PM
