all;
are all the '73 and earlier radio delete plates the same ?
thanks for any help.
cheers
jerry
all;
cheers
jerry
No.
The 65-68 cars have one. But I think from 69 -73, the dash is covered with material the same as left and right of thr radio.
this is the one i have. 155MM (~6 1/8) in lenght.
thanks for the reply.
best
jerry
edit: anybody have an example of the later style ?
Here is the one I have. the pics are not good but I dodged the part # to try to show it #911.552.436.02 I believe it is for a 73............ Sorry the attach files section only gives me examples of image appendage but no way to choose an image. Any one else having this problem?
67 Normale, Old Rusty
67 R Inspired and on a Diet
73 T/ST Caged Beast
RGruppe #383
S Registry #739
Looks like it's working now.
73 T/ST Caged Beast
RGruppe #383
S Registry #739
That's my understanding as well. The parts books appear to concur, in that the panel for non-radio car states "indicate color" as does the other fabric covered panels. Part # for it is 911 552 079 00Originally Posted by Rick Cabell
e
So how do you "fill" in the aluminum trim where the radio opening is before covering it in the material?Originally Posted by Soterik
Bill G.
EarlyS #718 | RGruppe #437
What I do is use some thin sheet steel about 22 gauge. This is thick enough to cover the hole and light enough as well. You find it at home centers as flashing for vents or for roofing. It is galvanized as well. I cut it so it fits with the cover material in the groove. Glue it all up with contact cement and your done. Hope this helps. Thanks Eric
I have tried the plastic radio delete plate but didn't work. The rounded corners don't match up so nice with the rest of the dash face. I think it's for post 73 cars. I am in with Eric911S, I used print plate and glued vinyl on it.
Cees
Nice solution. Where's a good source of vinyl for this? Thanks!
Jim Richards
Aubergine 1973 911E Sunroof Coupe w/ 2.7RS MFI
Early 911S Registry Member #589
GruppeB #911
