Thread: how do I remove paint from paint code plate?
    Dec 2004
    SE Michigan
    Need to safely remove a couple of coats of paint from the paint code plate. What can I use that won't also remove the black on the plate? Apparently, the PO thought the paint code plate was for painting on...
    Bill G.
    1968 911 Ossi Blue coupe...restoration complete!
    EarlyS #718 | RGruppe #437
    Yikes. If you have the balls, use spray can aircraft stripper. I have found it usually likes to soften the topmost layer of paint first. You might get lucky and be able to peel the top layer off, especially if the plate wasn't prepped for paint. Road film, etc. can act as a nice barrier to paint adhesion. On the other hand, you could damage the plate, too.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Senior Member red911's Avatar
    Sep 2005
    Rhode Island
    Hi Bill,
    International Merchantile sells door aluminum plates with your numbers stamped on the new plate for you.
    Good luck, Tom
    Bill,
    I ran across this problem on my '67S. I carefully masked around the plate...and made sure the masking tape was stuck as tightly as possible to the chassis (around the plate). I rubbed it several times with my hands at the edges of the plate. Then I carefully applied JASCO stripper. It pulled the paint off the plate without distrubing the black enamal underneath. I assumed that the black enamal was baked on and probably a little stronger than the paint sprayed over it. Maybe I got lucky because it worked fine. My paint number plate looks totally stock now and I didn't disturb the paint on the chassis around where it is attached. Good luck.
    Dec 2004
    SE Michigan
    Thank you, Richard, for the tip. I will try it.
    Bill G.
  1. 1972 Paint Code Plate - Help Please
    By sezme in forum General Info
    Last Post: 02-17-2023, 11:55 PM
  2. Paint Code Plate Font?
    By Irish911 in forum Technical Info
    Last Post: 02-11-2013, 05:15 PM
  3. Wanted: paint code plate w/ Conda green code
    By 9seriesguy in forum For Sale: 911 Parts
    Last Post: 11-05-2009, 07:33 PM
  4. 1972 Paint Code Plate - Help Please
    By sezme in forum Technical Info
    Last Post: 04-23-2009, 05:34 PM
  5. Paint code plate reinstallation question
    By neilk in forum General Info
    Last Post: 05-11-2004, 06:57 PM
