Results 1 to 9 of 9
Thread: Lets Play: "Name this Piston!"
    Ok, so I have these 90mm Mahle pistons and cylinders that I orginally thought were RS pistons. Upon further research and with the helpf of Chuck Miller, I have come to the conclusion that they are much higher compression - possibly 10.3:1. Can anyone help me with a positive ID?
    Oh, and I only have 5.........anyone got a sixth?
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
    One of the 2.2S pitons you just posted for sale?
    It sounds like you aren't 100% sure. Perhaps someone has the equipment to cc them that is near you?
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Quote Originally Posted by kenikh
    No, 2.2 are 84mm and these are 90mm. I guess I wasnt clear- this isnt a quiz, I really do not know what they are.
    Any help is appreciated
    10 sec 67 VW
    I missed the 90mm part.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    BTW, if you sent one to JE, Cosworth or Omega, I'm sure they'd be able to make you a dead ringer...for a price.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    RS pistons
    Hello: What I think you have there is a replacement RS style piston and cylinder set. The dome is higher on these with a compression of about 10:1 if used with 2.4 heads. If you use 2.7 heads it will be a little lower. If you use these with good gas and don't get carried away with your timing these work great. I would also run a little rich as well. I have also seen a couple of different style RS pistons as well. They call them Euro RS piston sets etc. Thanks Eric
    Quote Originally Posted by Rennman
    RSR 2.8.
    Don
    Those would be 92mm, but yeah, they look like them.
    Randy Wells
    www.randywells.com/blog
    www.hotrodfilms.com
    Early S Registry #187
    Yes, but these are 90mm......I have two sets of cylinders I checked them with.
    10 sec 67 VW
  1. FS: Special Extended Hub 380mm "RS" "RSR" Thick Grip Steering Wheel
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 06-06-2014, 12:47 PM
  2. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 03-09-2012, 07:53 PM
  3. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 03-03-2012, 08:51 AM
  4. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 02-18-2012, 09:24 PM
  5. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 01-24-2012, 01:59 PM
