Results 1 to 10 of 12
Thread: Is it ok to use gasket sealer on lower valve covers?
    Hello all,
    The lower valve covers on my 69 T have been leaking, making it almost undriveable due to the burning oil and smoke/odor. I installed a set of used Turbo valve covers, but they're still leaking! Is it ok to use a bead of gasket sealer to get a better seal? Is there some other solution? Should I have the upper and lower covers machined? Help!
    Thanks.
    Zach Mayne
    1969 911T, 1988 924S, 1985 635CSi, some Alfas and a Fiat....
    Could be leaking from another source. Leaks from above will drip onto this area. Take a look at the rocker arm shafts. The area between rockers should be dry. What side is the leak?
    Could also be:
    - Cam housing oil supply line
    - Oil pressure sending unit
    - Engine oil temp. thermostat
    - Oil temp. sending unit
    - Joint between cam housing and cylinder head
    - Upper valve cover
    - Oil drain tube(s)
    - Camshaft end plug in cam housing
    - Crankcase breather housing
    The above are the normal sources.
    Sherwood
    Suffolk, VA
    Sherwood is right here. Those are the typical spots.
    Citation F1000 on the way
    Other Early 911/912/914
    Goldmember ttweed's Avatar
    La Jolla, CA
    I have always been told to install the valve cover gaskets DRY. If they do not seal, the surfaces are not clean and flat. Gasket sealer should NOT be used, IMHO.
    Or, the leak might be from somewhere else, as Sherwood suggests.
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    I've heard raves on the new reusable silicone gaskets..
    Mar 2005
    I have the same problem. I installed upper and lower covers and there is still a leak. I am trying to trace the leak to the source. I am thinking it could be coming from the oil cooler forward of the engine.
    don
    _________________
    1963 356B Super
    1969 911S
    1981 911SC
    Quote Originally Posted by ttweed
    TT
    I had a feeling it wasn't a good idea to use sealer. Back to the drawing board...
    Zach Mayne
    Card carryin' member! mjmoran's Avatar
    Aug 2003
    Its also a good idea to check flatness of the valve cover. Use of a straight edge and a flat surface (like the wifes granite kitchen countertop) is a great source. Then, if needed a bit of wet-dry paper to flatten out the sealing surface on the cover...
    You should not need gasket sealer though...thats for those other cars
    Michael
    72 911S Coupe, Sepia Brown
    Thanks guys!
    Ok, so I'll take off all the valve covers, check them for flatness and if it still leaks I'll try driving it off a cliff...
    Zach Mayne
    Jun 2003
    Toronto
    It is also very important to use new "crush" washers and Nyloc nuts every time you re-install the covers, and do not over torque.
  1. FS: Lower valve covers
    Last Post: 01-04-2014, 05:30 AM
  2. WTB: 930 Lower valve covers...
    By Rocket534 in forum For Sale: 911 Parts
    Last Post: 04-24-2013, 07:55 AM
  3. FS - early lower valve covers
    By haycait911 in forum For Sale: 911 Parts
    Last Post: 04-05-2010, 04:40 PM
  4. FS: lower Turbo valve covers
    By kenikh in forum For Sale: 911 Parts
    Last Post: 07-13-2009, 12:14 PM
  5. FS: Turbo lower valve covers
    Last Post: 10-27-2008, 06:44 PM
