Thread: Replacing Door seals
    Planning on replacing my 35 yr old door seals on my 911E
    this weekend. Is there any special trick or proceedure?
    Looks pretty straight foward. I have new seals from Pelican &
    a can of Wurth rubber glue.
    Any advice would be appreciated
    1973 911E Viper Green
    2021 Spyder PTS Signal Yellow
    2019 Carrera T Racing Yellow
    2008 Boxster S Ltd. Ed Orange
    2007 911 GT3 Meteor Grey
    @Type911 instagram
    RGruppe #295
    Zuffenhausen secret weapon
    DynoDave
    Dec 2004
    Highlands Ranch, CO
    Replacing door seals
    Use a good general purpose cleaner to remove the talcam powder &/or mold release agent before applying the Wurth adhesive to your new seals. Also, make sure that the weatherstrip channel on the body is clean before installing the new seals.
    Dave
    Member # 351
    Nov 2002
    Worshington State
    After doing your test fit, start at the bottom, glue that in and slowly work your way up the sides. Do the upper part last. Be sure to take your time. And no sniffing along the way!
    Jun 2005
    Perth WA
    Lightbulb
    If you are uusing the 3M weathershield adhesive wear a mask - I got a 2 day headache after glueing mine!!
  1. Door Seals
    By sithot in forum Technical Info
    Last Post: 06-12-2023, 01:29 PM
  2. Replacing the 'fuzzy' door glass channels?
    Last Post: 10-05-2013, 05:13 AM
  3. Replacing Window Seals - Best Place to Buy Them?
    By 313green in forum Technical Info
    Last Post: 04-13-2011, 08:20 PM
  4. WANTED: door handle seals for 1969 door handles
    By obrut in forum For Sale: 911 Parts
    Last Post: 05-15-2010, 06:15 PM
  5. Ballpark cost for replacing all body seals?
    By ibmiked in forum General Info
    Last Post: 07-09-2009, 04:55 PM
