Thread: MFI question ?
    MFI question ?
    Is the MFI set up ( Pump,Stacks&Throttle bodies) on a 73' E the same as a 73" S ...... and is the part # the same ? .... anyone !?.
    Thanx
    T
    Jun 2003
    Toronto
    No, different pump, throttle bodies on an "S" have larger bores to accomodate larger port "S" heads, stacks I don't know.
    Jan 2003
    NW Indiana
    All those components (stacks too) are different from the 2.4L 'E' to 'S' system. The 'E' system, at a high cost, can be changed to 'S' specs by various shops. That may be the way to go because buying a complete 'S' system has probably become more expensive than redoing an 'E' system.
    As an aside the 2.4L 'S' system shared the same throttle bodies and stacks with the 2.7L 'RS' system and that is another reason the costs have become so high for the original parts.
    Brian
    '71T
    R Gruppe #299
  1. Replies: 5
    Last Post: 03-19-2015, 10:54 AM
  2. Rsr question
    Last Post: 09-02-2012, 11:28 AM
  3. Replies: 2
    Last Post: 07-13-2011, 07:15 PM
  4. Value Question
    Last Post: 01-08-2009, 01:44 PM
  5. ST Question
    By Chuck Miller in forum Technical Info
    Last Post: 12-08-2005, 01:53 PM
