Thread: Matching metals
    Mar 2005
    Matching metals
    I am rebuild my 69S engine. I am thinking of replacing the chain housing. Since the case is mag, I assume the chain housing is mag. My mechanic says mag chain boxes are not worth a darn and I should replace it with a aluminmum case. But I think the matching metal that expand at different rates is a problem. The reason I would replace the housing is the it interface b/t the housing and the case may be a source of an oil leak I need to get rid of. Ideas?
    b
    I think that the ally and mag housings have differend mountings so are not interchangable.
    Mar 2005
    My mechanic says that the original chainboxes on mag engines often warp and
    he replaces them with a chainbox from an SC. He says he has did it many times and it works.
    Quote Originally Posted by dhopkins
    Don:
    Your mechanic is a wise & enlightened person; he is right.
    Aside from the color differences between the magnesium and aluminum chainboxes, this is really a good upgrade and cures/prevents a whole myriad of oil leaks.
    SC chainboxes fit all of the magnesium cases (1R, 2R/3R, 4R/5R, & 7R) and can be retrofitted to the early sand-cast cases for a more leak-free engine.
    (edited for kenikh )
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    Quote Originally Posted by Steve@Rennsport
    Don:
    SC chainboxes fit all of the magnesium cases (2R/3R, 4R/5R, & 7R) and can be retrofitted to the early sand-cast cases for a more leak-free engine.
    You said all, but didn't mention 1R mag cases specifically. I assume it works on these as well?
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Whoops. When I said they were not interchangable I was refering to pre 68 ally chain cases.
  1. 1969 911s value matching numbers vs non matching
    By frankmar in forum General Info
    Last Post: 02-26-2015, 09:53 AM
  2. WTD 911 S 69/70 must be matching
    By froggy in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 03-13-2011, 09:46 AM
  3. FS: '68 S SWT Matching #'s
    By popowitz in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 08-25-2010, 06:29 AM
  4. How do you tell if a car has matching #s
    By dhopkins in forum General Info
    Last Post: 08-01-2010, 10:35 PM
  5. Value of 72S with non matching #
    By dmcummins in forum General Info
    Last Post: 07-29-2004, 06:24 AM
