Thread: Updating to 67 S REAR brakes
    All,
    I'm new here. I have searched the archives and found alot of useful information but I still have a question...
    I have a 67 912. I am updating the front suspension to that of a 73 911 Carrera. The struts I am using are 3.5" Bilstien struts with "A" calipers. I have access to a 67 911 S parts car that still has the original ventilated rear rotors and calipers. I have read about using the early 944 rear rotors and that's not a problem. My question is, can I just use the rotors and calipers or do I need the hubs off the car as well to keep the spacing equal to the front?
    --Tony
    67 912 2.0 type 4 conversion
    http://Gumby912.servebeer.com
    67 911S Rear brake upgrade underway
    All,
    I grabbed everything (calipers, rotors, backing plates, stub axles, etc) from the 67 911S wreck. I should have everything needed to upgrade my rear brakes. I got lucky on the rotors. 18.0mm is the wear limit, both of the used rotors measured out at 19.5mm so I am good.
    Where can I get a caliper rebuild kit for these calipers? 67 911S vented steel 3" calipers.
    --Tony
    http://gumby912.servebeer.com
    More than Original
    Jun 2004
    SoCal
    Rebuild kit: 901.352.998.00 (actually for rear M Caliper) Pelican Parts
    More info here http://forums.pelicanparts.com/showt...hreadid=225135
    Bret Davis
    1968 911L
    Thanks!
    B D,
    Thanks for the info. I actually had read that thread a few times but if you follow the other thread links in there, you can get yourself pretty confused.
    You never responded to that thread as to how your 944 rear rotor upgrade worked out. Or did you and I missed it?
    --Tony
  1. Replies: 11
    Last Post: 12-10-2012, 02:58 PM
  2. FS: SWB 1966 Front and Rear Suspension (and Brakes)
    By greggearhead in forum For Sale: 911 Parts
    Last Post: 06-07-2011, 06:16 PM
  3. Early 911 rear brakes
    Last Post: 05-04-2011, 12:44 PM
  4. SWB rear vented brakes question
    By haycait911 in forum Technical Info
    Last Post: 12-11-2009, 05:11 AM
  5. WTB; cross over hard line rear brakes
    By Zithlord in forum For Sale: 911 Parts
    Last Post: 09-25-2009, 10:28 AM
