Results 1 to 8 of 8
Thread: Pre 73 Tool kit info
    Hi all,
    Can any one confirm if tool kits pre 73 came with a "fuse" pack. Which was a small Burgundy packet containing 5 fuses and also a Porsche towel?
    Also can anyone confirm what the material was for a 70-71 tool kit roll. Should it be "basket" weave textured like the dash insert and door panels.
    If so, when the tool kit roll change to the later smooth material
    It may sound techy, but I want the correct kit for 71S.
    Alan
    Jul 2003
    Santa Cruz, CA
    Basketweave with the clasps for 71. Don't know about the burgundy packet for the fuses but, "plastic bag containing five fuses" is listed in the 71 parts manual. 914.721.013.10
    No listing for the towel. I've heard that it was not factory.
    Also listed in the parts manual is the bottle of glycerine 901.721.010.10
    Cheers and beers,
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    The fuse "bag" in my '72 tool kit is NOT the burgandy thing, which is what I suspect is used these days because the original was fragile and is NLA. Best way I can decribe it is a little box of clear plastic that slides open & closed like a small plastic aspirin tin. Also, good luck finding the original (yellow) 5 amp fuse...
    Thanks for the information. I have attached some pics of the Burgundy Fuse pack that I have, with the fuses. I am still uncertain what year this is from? I also think I have the fuse pack that open and slides, I will get some pics to confirm if it is the original one.
    Do you ever see the "bottle of glycerine 901.721.010.10" for sale?
    Thanks again
    Alan
    Nov 2003
    Sydney
    Alan,
    FWIW to me, your fuse pack looks too recent to be an original 2.2 tool kit part.
    I have the small plastic slide box,which is a bit fragile these days(just like some Sunday mornings for me ) and I suspect that this one is the more original of the two.
    I am interested in your findings as my car is a similar UK delivered '71 2.2S.
    Keep me posted.
    Cheers,
    Dennis.
    S Registry member 536
    Alan,
    Tool kit should be basketweave similair to door panels/dash etc
    Should have silver clasps
    Paul is spot on clear, hard plastic container with sliding lid for fuses.
    Spoanners should have Drop Forged steel marked on them.
    Plug spanner does not have the rubber insert and is smaller than later (73) style
    Pliers should not have Hapewe on them just made in Germany.
    The screwdirers I am not 100% sure about it either the reversable style or two single units. Someone smarter than I can help there.
    Not sure when smooth started certainly after 73 or at least very very late 73.
    Where is Eric when you need him
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    www.spyderautomobiles.com .au
    Feb 2005
    Australia
    Quote Originally Posted by Alan.uk
    Hi all,
    Alan
    Alan,
    I think the fuse pack you have is the one Stoddards list in their 356 catalogue, found on this page (item 7):
    http://www.stoddard.com/shop/shopdis...y+%26+Fuse+Box
    Cheers,
    Lisa Gregory
    Early 911S Registry #726
    www.spyderautomobiles.com.au
    Thanks again for the info
    Alan
  1. FS: Late 'JUSIN' Tool Bag for TOOL KIT
    By METAVINYL in forum For Sale: 911 Parts
    Last Post: 12-21-2013, 01:34 PM
  2. FS: KLEIN 21 Spark Plug Tool w/ Allen Key LWB Tool Kit
    Last Post: 09-27-2013, 04:18 PM
  3. Factory tool kit info 911
    By georgepvalerio in forum General Info
    Last Post: 11-28-2011, 06:04 AM
  4. Tool Kit info for a '73
    By kentf14 in forum Technical Info
    Last Post: 04-26-2010, 11:29 AM
  5. 66 911 tool info
    By Rick Cabell in forum General Info
    Last Post: 10-03-2005, 08:12 AM
