Thread: 1972 911S engine compartment color
    Can Anyone confirm the correct color of the engine compartment? Should it be painted satin black? Or body color? The car is Light Ivory.
    Steve Lawrence
    Black is correct
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Black...and brush it on if you're really looking for "proper". That's so flecks of body color will show. I'm reasonably sure the black was brushed on...though you can't see the flecks of color in this pic, they are there. My car is still original paint.
    IIRC, it painted body color with the black brushed on top - hence the flecks that show. Right?
    And is the black a paint, or a goo of wome sort? My '73.5 had black but it was a softer surface than most paint...
  1. 1972 Engine Lid Letter Color
    By FL-Frank in forum Technical Info
    Last Post: 05-31-2020, 06:05 PM
  2. 1972 911s with 911/83 engine value
    By Hodijag in forum General Info
    Last Post: 02-01-2016, 05:49 PM
  3. Engine compartment paint and color code
    By ferry58 in forum Technical Info
    Last Post: 10-12-2009, 12:12 PM
  4. Engine Compartment Color Suggestions
    By J-P in forum Technical Info
    Last Post: 08-06-2006, 09:40 PM
  5. What is the color of your engine compartment?
    Last Post: 06-20-2006, 05:40 PM
