Results 1 to 7 of 7
Thread: Marelli Twin plug distributor etc
    I need help in identifying what is supposed to be a Marelli Twin plug distributor, twin plug cap, rotor and NOS lead holders.
    I have seen other pics of Marelli distributors from the late 60's but nothing quite like this one.
    I wish to sell the unit but don't want to misrepresent it in nay way so I need help.
    For sure the cap is original Marelli as its stamped on it but there are no Marelli markings of any sort on the distributor although all the special slots in the cap line up perfectly on the top of the distributor. It may have had a Marelli decal which no longer exists.
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    clyde
    you should give spencer harrison a call - i think he's looking for one (well he offered to buy mine last time i spoke to him...)
    Cheers, Ryan
    Founder and chief centre cap remover at : ZOLLHAUS / Design driven custom PORSCHE : https://zoll.haus
    Senior Member BURN-BROS's Avatar
    Sep 2003
    Camarillo, Ca.
    It looks like a Ferarri body with a custom bottom. or a stock bottom for a different application. Very odd.. I'll try to find some pics. It has a twin plug rotor installed but how many lobes does the shaft have? Three for a six cylinder twin plug and six for a 12 cylinder single plug. Also the dizzy gear does not look like a Porsche. Maserati perhaps?
    Aaron Burnham
    Burnham Performance
    1071 Avenida Acaso ste D.
    Camarillo, Ca. 93012
    805-240-6931
    _________________________
    Aug 2003
    Van Nuys, Ca
    that is what i am thinking too; twin plug maserati six cylinder. the caps and rotors are what were supplied to porsche - same parts there.
    As with most anything , with enough machining and some aluminum/ steel, one could make this into a porsche application
    Member #755
    Conda Green 70 911S
    70 black 914-6 3.2
    70 911 "Speedster" project
    "74 IROC" tribute Jade Green RSR
    Shaft has 6 lobes
    Clyde Boyer
    If the unit runs twin points and twin condensors does that not mean it should have 6 lobes for a 6 cylinder? (remember I am mechanically deficient)
    Clyde Boyer
    Sep 2003
    Camarillo, Ca.
    I am pretty sure that 6 lobe shaft is a 12 cylinder application. The 911 R/RSR lobe uses a 3 lobe. I would ebay the cap and rotor for crazy money on E-bay and sell the dizzy once you are sure of its application. There were not many cars that used such a unit. I have seen Ferarri dizzys go for $500.00 to $600.00. Hope this helps.
    Aaron Burnham
    Burnham Performance
    805-240-6931
  1. Porsche 911 RSR 2.8 Marelli Twin Plug Distributor OEM
    By 914-6gt in forum For Sale: 911 Parts
    Last Post: 04-23-2021, 01:08 AM
  2. FS: original Marelli 906 / 911 R / 911 ST twin plug distributor NOS
    By 911r67 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 12-22-2013, 07:18 AM
  3. Marelli twin plug distributor cap-used
    By JT912 in forum For Sale: 911 Parts
    Last Post: 03-21-2012, 11:25 PM
  4. Marelli twin plug distributor for Porsche 911 RS RSR S ST
    By 72targa in forum For Sale: 911 Parts
    Last Post: 10-01-2008, 08:26 PM
  5. Replies: 7
    Last Post: 02-15-2007, 09:31 PM
